[mapserver-users] MapServer 5.2.1 performance
Andy Colson
andy at squeakycode.net
Wed Sep 2 11:04:45 EDT 2009
Wow... Yeah, I totally missed that. I need to stop drinking the heavy
liquor in the morning. :-)
-Andy
Christopher Schmidt wrote:
> On Wed, Sep 02, 2009 at 09:10:54AM -0500, Andy Colson wrote:
>>> * I see that most of the layers spent around 0,015 seconds for each. Some layers spent around 0.25 seconds and I could see that these layers have few geometries very complex (I try to break these geometries in others simpler)
>> As I see it, you have two options:
>> 1) Make an individual request faster (hard to do)
>> 2) Reduce the number of requests (easier, and different options)
>> Do you really need all 120 layers? For one tile you have to make 120
>> requests. If it takes 4 tiles to fill out your map, thats 4 * 120 = 480
>> requests. If you could combine a few layers you would reduce the
>> number of requests, and improve performance.
> Er, I think your'e confused. His *mapfile* has 120 layers -- 40 of which
> are 'within range', 80 of which are not, and he's putting those
> 40 layers into one tile. (This is large, but not excessive; the Boston
> Freemap had something like 60 layers, and was a pretty simple map, all
> things considered.)
> I could be reading this wrong, but I think you're misunderstanding the
> problem.
> -- Chris
>> Have you tried using multiple urls in OpenLayers?
>> see:
>> http://openlayers.org/dev/examples/multiserver.html
>> Have you used firebug to watch it load? It has a nice pretty graph that
>> shows which requests are concurrent, the time for each, etc, etc.
>> If you can switch any of your layers to load as a single tile that would
>> also cut down the number of requests (from 4 to 1 in the example above).
>> -Andy
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
