[mapserver-users] problem with WMS GetFeatureInfo and GML
Steve.Toutant at inspq.qc.ca
Fri Sep 4 13:19:27 EDT 2009
Hello,
Via openlayers I launch an url to mapserver (v5.2.1) which returns a GML.
See the URL and the response below. I put the layer definition of the
mapfile as well.
I'm not sure if my problem is on mapserver or on openlayers side. The
problem is I can't add the geometry to the openlayers vector layer for
some reasons. As if the geometry was null.
If someone could confirm that everything is ok or not on mapserver side
would help me.
thanks in advance for your help,
Steve
LAYER
NAME "national_2006"
GROUP "Vulnerabilite"
CONNECTIONTYPE postgis
CONNECTION "host=10.2.192.247 dbname=geo user=dbaInspq
password=!dbaInspq! port=5432"
DATA "geom900913 FROM lim_admin.inddef_2006 using unique gid"
TYPE POLYGON
STATUS off
PROJECTION
"init=epsg:900913"
END
PROCESSING "CLOSE_CONNECTION=DEFER"
METADATA
"wms_title" "Indice de défavorisation national 2006"
"wms_group_title" "Vulnérabilité"
'wms_srs' 'EPSG:4326 EPSG:32198 EPSG:900913'
"wms_include_items" "all"
"gml_include_items" "ad,quintmat,quintsoc"
'gml_featureid' 'gid'
END
DUMP TRUE
TOLERANCE 0
TEMPLATE '../template/query_indiceDef.html'
HEADER '../template/query_header.html'
FOOTER '../template/query_footer.html'
INCLUDE "/ms4w/inspq/map/Class_IndiceDefavorisation.map"
END
http://10.2.192.247/cgi-bin/mapserv.exe?map=/ms4w/paccSante/map/paccsante_chaleur.map&&service=WMS&version=1.1.0&request=GetFeatureInfo&layers=national_2006&query_layers=national_2006&styles=&bbox=-8225541.519129%2C5696087.269543%2C-8187017.256881%2C5719324.126138&srs=EPSG%3A900913&feature_count=10&x=425&y=500&height=608&width=1008&info_format=application%2Fvnd.ogc.gml
And the response is this:
<?xml version="1.0" encoding="ISO-8859-1"?>
<msGMLOutput
xmlns:gml="http://www.opengis.net/gml"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<national_2006_layer>
<national_2006_feature>
<gml:boundedBy>
<gml:Box srsName="EPSG:900913">
<gml:coordinates>-8212506.502737,5697097.841728
-8204853.558950,5702856.964043</gml:coordinates>
</gml:Box>
</gml:boundedBy>
<ad>24662464</ad>
<quintmat>1</quintmat>
<quintsoc>2</quintsoc>
</national_2006_feature>
</national_2006_layer>
</msGMLOutput>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090904/eabdc4ea/attachment.html
