[mapserver-users] problem with WMS GetFeatureInfo and GML
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Fri Sep 4 13:28:44 EDT 2009
Hi Steve,
there is no way to output a geometry with WMS GetFeatureInfo right now,
see also:
http://trac.osgeo.org/mapserver/ticket/2989
You would better use a WFS GetFeature request.
Best regards,
Bart
Steve.Toutant at inspq.qc.ca wrote:
> Hello,
> Via openlayers I launch an url to mapserver (v5.2.1) which returns a
> GML. See the URL and the response below. I put the layer definition of
> the mapfile as well.
> I'm not sure if my problem is on mapserver or on openlayers side. The
> problem is I can't add the geometry to the openlayers vector layer for
> some reasons. As if the geometry was null.
> If someone could confirm that everything is ok or not on mapserver
> side would help me.
> thanks in advance for your help,
> Steve
> LAYER
> NAME "national_2006"
> GROUP "Vulnerabilite"
> CONNECTIONTYPE postgis
> CONNECTION "host=10.2.192.247 dbname=geo user=dbaInspq
> password=!dbaInspq! port=5432"
> DATA "geom900913 FROM lim_admin.inddef_2006 using unique gid"
> TYPE POLYGON
> STATUS off
> PROJECTION
> "init=epsg:900913"
> END
> PROCESSING "CLOSE_CONNECTION=DEFER"
> METADATA
> "wms_title" "Indice de défavorisation national 2006"
> "wms_group_title" "Vulnérabilité"
> 'wms_srs' 'EPSG:4326 EPSG:32198 EPSG:900913'
> "wms_include_items" "all"
> "gml_include_items" "ad,quintmat,quintsoc"
> 'gml_featureid' 'gid'
> END
> DUMP TRUE
> TOLERANCE 0
> TEMPLATE '../template/query_indiceDef.html'
> HEADER '../template/query_header.html'
> FOOTER '../template/query_footer.html'
> INCLUDE "/ms4w/inspq/map/Class_IndiceDefavorisation.map"
> END
> http://10.2.192.247/cgi-bin/mapserv.exe?map=/ms4w/paccSante/map/paccsante_chaleur.map&&service=WMS&version=1.1.0&request=GetFeatureInfo&layers=national_2006&query_layers=national_2006&styles=&bbox=-8225541.519129%2C5696087.269543%2C-8187017.256881%2C5719324.126138&srs=EPSG%3A900913&feature_count=10&x=425&y=500&height=608&width=1008&info_format=application%2Fvnd.ogc.gml
> And the response is this:
> <?xml version="1.0" encoding="ISO-8859-1"?>
> <msGMLOutput
> xmlns:gml="http://www.opengis.net/gml"
> xmlns:xlink="http://www.w3.org/1999/xlink"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
> <national_2006_layer>
> <national_2006_feature>
> <gml:boundedBy>
> <gml:Box srsName="EPSG:900913">
> <gml:coordinates>-8212506.502737,5697097.841728
> -8204853.558950,5702856.964043</gml:coordinates>
> </gml:Box>
> </gml:boundedBy>
> <ad>24662464</ad>
> <quintmat>1</quintmat>
> <quintsoc>2</quintsoc>
> </national_2006_feature>
> </national_2006_layer>
> </msGMLOutput>
> mapserver-users at lists.osgeo.org
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
