[mapserver-users] display feature name beside feature
Michael Schulz
mschulz at webgis.de
Fri Sep 18 09:43:50 EDT 2009
you can use the labeling options mapserver offers. Labeling can be
accomplished by adding a label section to a class of a layer. You can
define the labelitem aka. a fieldname of a shape's attributes or a
database table, that mapserver takes the value from to actually label
a feature.
Read on here:
- http://mapserver.org/introduction.html#label
- http://mapserver.org/mapfile/label.html
If you want to have the labeling as a separate layer, that can be
turned on and off, you should have a look at the annotation layer
type.
Cheers, Michael
2009/9/18 sunny74 <sb.ray at hotmail.com>:
> Hi,
> I have a number of features(Layers) in my map.One of the feature is a Water
> Body.
> How can I display the feature name beside the feature?
> Is there anything in the map file which can do this or do I have to do this
> thru' coding in js?
> I am using mapserver v 5.0.0 with openlayers.
> If anybody has a solution pls mention in detail.
> Thanks for your reply.
> View this message in context: http://n2.nabble.com/display-feature-name-beside-feature-tp3668538p3668538.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
Besuchen Sie uns auf der INTERGEO 2009: 22.09. - 24.09.2009 in Karlsruhe;
Halle 1, Stand 1.417
Aufwind durch Wissen!
Qualifizierte Open Source Schulungen bei der
http://www.foss-akademie.de/
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
+++ Bitte beachten Sie unsere neue Adresse und Durchwahl +++
Schwimmbadstraße 2
D-79100 Freiburg i. Br.
Tel: +49 (0)761 705798-102
Tel: +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
