[mapserver-users] display feature name beside feature
sunny74 sb.ray at hotmail.com
Sun Sep 20 13:49:14 EDT 2009
Hi Michael,
Thanks for your reply.
I had gone thru' the links you have given before making this post.But I am
having the problems given in the link below:
http://n2.nabble.com/font-error-while-trying-to-show-Label-on-map-td3654455.html#a3654455
When using truetype I get the error probably bec' I am not able to specify
the fontset file.
So I need to know the following:
1) What kind of file is the fontset file?I think it is a text file
2) Where do I keep the fontset file - in the same folder as the map file or
in different folder.If different folder how do I specify the path in the map
file.
3) Where do I keep the fonts? Is it okay if I keep it in the Windows Font
Folder i.e C:/Windows/Fonts
4)How do I specify the path of the fonts in the fontset file?
Pls give ur answer so as to solve this problem.
After
Michael Schulz wrote:
> Hi,
> you can use the labeling options mapserver offers. Labeling can be
> accomplished by adding a label section to a class of a layer. You can
> define the labelitem aka. a fieldname of a shape's attributes or a
> database table, that mapserver takes the value from to actually label
> a feature.
> Read on here:
> - http://mapserver.org/introduction.html#label
> - http://mapserver.org/mapfile/label.html
> If you want to have the labeling as a separate layer, that can be
> turned on and off, you should have a look at the annotation layer
> type.
> Cheers, Michael
> 2009/9/18 sunny74 <sb.ray at hotmail.com>:
>> Hi,
>> I have  a number of features(Layers) in my map.One of the feature is a
>> Water
>> Body.
>> How can I display the feature name beside the feature?
>> Is there anything in the map file which can do this or do I have to do
>> this
>> thru' coding in js?
>> I am using mapserver v 5.0.0 with openlayers.
>> If anybody has a solution pls mention in detail.
>> View this message in context:
>> http://n2.nabble.com/display-feature-name-beside-feature-tp3668538p3668538.html
>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Besuchen Sie uns auf der INTERGEO 2009: 22.09. - 24.09.2009 in Karlsruhe;
> Halle 1, Stand 1.417
> Aufwind durch Wissen!
> Qualifizierte Open Source Schulungen bei der
> http://www.foss-akademie.de/
> Michael Schulz
> mschulz at webgis.de
> in medias res
> Gesellschaft für Informationstechnologie mbH
> +++ Bitte beachten Sie unsere neue Adresse und Durchwahl +++
> Schwimmbadstraße 2
> D-79100  Freiburg i. Br.
> Tel:  +49 (0)761 705798-102
> Tel:  +49 (0)761 705798-0
> Fax: +49 (0)761 705798-09
> http://www.webgis.de / http://www.zopecms.de
> Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
> Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
View this message in context: http://n2.nabble.com/display-feature-name-beside-feature-tp3668538p3681031.html
