[mapserver-users] MINSCALEDENOM did not work?
Alphatran bicphuongonline at yahoo.com
Mon Sep 21 06:36:32 EDT 2009
Rahkonen Jukka wrote:
> Hi,
> Minscaledenom does work for me as supposed.  If I set it to value 1:10000
> I can see the layer in scale 1:11000 because scale demoninator is bigger
> than my limit.  In scale 1:9000 it does not show.  But I see that you have
> understood correctly that because map scale is a division, big number
> under the line means small scale.
> MINSCALEDENOM is used just as you have done, by adding a line into LAYER
> definitions. I have no idea why it would not work.
> -Jukka Rahkonen-
Dear Rahkonen,
I understand now. But I cannot make it's working. I set MINSCALEDENOM 6319
(this is scaledenom of level 8) but it make the tile is empty with grey
color for all levels . Remove it away, the layer is working normal.
Have you experienced on this?
View this message in context: http://n2.nabble.com/MINSCALEDENOM-did-not-work-tp3637534p3684387.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
