[mapserver-users] mapserver files to subdomain results in
'500Internal Server Error' when mapserv executable accessed
through url
Steve Lime
Steve.Lime at dnr.state.mn.us
Mon Sep 21 15:16:33 EDT 2009
Typically I would think this is a linking error. That is, the mapserv binary can't find the shared
libs it needs to run. You probably need to configure apache further. There's a LD_LIBRARY_PATH
env variable that you can look into setting.
Steve
>>> On 9/21/2009 at 2:03 PM, in message <1253559809841-3687559.post at n2.nabble.com>,
Ted Spradley <tspradley at snoogems.com> wrote:
> Hi all,
> I decided it would be a good idea to move all of my mapping activity to a
> subdomain: maps.subdomain.com
> Accessing mapserv by 'http://maps.domain.com/cgi-bin/mapserv' the result
> is '500 Internal Server Error'.
> Accessing mapserv by 'http://domain.com/cgi-bin/mapserv' the result
> is the expected 'No query information to decode. QUERY_STRING is set, but
> empty. '.
> access_log shows the two requests converted to the same GET:
> 1. 'http://domain.com/cgi-bin/mapserv' -
> [21/Sep/2009:12:40:12 -0500] "GET /cgi-bin/mapserv HTTP/1.1" 200 249 "-"
> "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.1.3) Gecko/20090824
> Firefox/3.5.3 (.NET CLR 3.5.30729)"
> 2. 'http://maps.domain.com/cgi-bin/mapserv' -
> [21/Sep/2009:12:40:20 -0500] "GET /cgi-bin/mapserv HTTP/1.1" 500 1549 "-"
> One gets code 200, Two gets code 500.
> error_log shows:
> [Mon Sep 21 12:40:20 2009] [error] [client 98.200.238.238] Premature end of
> script headers: mapserv
> mapserv -v
> MapServer version 5.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=ICONV
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=THREADS INPUT=EPPL7
> INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> MapServer is now configured for
> -------------- Compiler Info -------------
> C compiler: gcc -O2 -fPIC -Wall
> C++ compiler: g++ -O2 -fPIC -Wall
> Debug: -DNEED_NONBLOCKING_STDERR
> Generic NINT:
> -------------- Renderer Settings ---------
> zlib support: -DUSE_ZLIB
> png support:
> palette rgba png support:
> jpeg support:
> iconv support: -DUSE_ICONV
> AGG support:
> AGG Freetype support:
> Ming(flash) support:
> PDFLib support:
> -------------- Support Libraries ---------
> Proj.4 support: -DUSE_PROJ
> Libxml2 support: -DUSE_LIBXML2
> FriBidi support:
> Curl support: -DUSE_CURL
> FastCGI support:
> Threading support: -DUSE_THREAD
> GEOS support:
> -------------- Data Format Drivers -------
> native tiff support:
> PostGIS support: -DUSE_POSTGIS
> EPPL7 support: -DUSE_EPPL
> ArcSDE support:
> OGR support: -DUSE_OGR
> GDAL support: -DUSE_GDAL
> Oracle Spatial support:
> -------------- OGC Services --------------
> WMS Server: -DUSE_WMS_SVR
> WMS Client: -DUSE_WMS_LYR
> WFS Server: -DUSE_WFS_SVR
> WFS Client: -DUSE_WMS_LYR
> WCS Server: -DUSE_WCS_SVR
> SOS Server:
> -------------- MapScript -----------------
> PHP MapScript: yes
> Installation: Fedora 7, Linux Apache/2.2.8
> Does anyone have any thoughts about where I may start looking for clues?
> Thank you,
> Ted S.
