[mapserver-users] mapserver files to subdomain results in
'500Internal Server Error' when mapserv executable accessed through url
Ted Spradley
tspradley at snoogems.com
Mon Sep 21 19:09:54 EDT 2009
Thanks Steve.
I added SetEnv LD_LIBRARY_PATH /usr/local/lib to /etc/httpd/conf/httpd.conf
as follows:
<Directory "/var/www/cgi-bin">
AllowOverride None
Options None
Order allow,deny
Allow from all
</Directory>
and restarted Apache, but I know I am only guessing. No success.
Then I tried setting the environment variable by adding 'SetEnv
LD_LIBRARY_PATH /usr/local/lib'
to the /var/www/vhosts/domain/conf/httpd.include file as follows:
<VirtualHost xxx.xxx.xxx.xx:80>
ServerName maps.domain.com:80
SuexecUserGroup snoogadmin psacln
ServerAdmin "admin at domain.com"
DocumentRoot /var/www/vhosts/domain.com/subdomains/maps/httpdocs
CustomLog /var/www/vhosts/domain.com/statistics/logs/access_log
plesklog
ErrorLog /var/www/vhosts/domain.com/statistics/logs/error_log
ScriptAlias /cgi-bin/ /var/www/cgi-bin/
and restarted Apache, but with the same result of '500 Internal Server
Error'.
Possibly I need to be entering different parameters into the LD_LIBRARY_PATH
variable?
Thanks again,
Ted S
Steve Lime wrote:
> Typically I would think this is a linking error. That is, the mapserv
> binary can't find the shared
> libs it needs to run. You probably need to configure apache further.
> There's a LD_LIBRARY_PATH
> env variable that you can look into setting.
> Steve
>>>> On 9/21/2009 at 2:03 PM, in message
>>>> <1253559809841-3687559.post at n2.nabble.com>,
> Ted Spradley <tspradley at snoogems.com> wrote:
>> Hi all,
>> I decided it would be a good idea to move all of my mapping activity to a
>> subdomain: maps.subdomain.com
>> Accessing mapserv by 'http://maps.domain.com/cgi-bin/mapserv' the result
>> is '500 Internal Server Error'.
>> Accessing mapserv by 'http://domain.com/cgi-bin/mapserv' the result
>> is the expected 'No query information to decode. QUERY_STRING is set, but
>> empty. '.
>> access_log shows the two requests converted to the same GET:
>> 1. 'http://domain.com/cgi-bin/mapserv' -
>> [21/Sep/2009:12:40:12 -0500] "GET /cgi-bin/mapserv HTTP/1.1" 200 249 "-"
>> "Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.9.1.3)
>> Gecko/20090824
>> Firefox/3.5.3 (.NET CLR 3.5.30729)"
>> 2. 'http://maps.domain.com/cgi-bin/mapserv' -
>> [21/Sep/2009:12:40:20 -0500] "GET /cgi-bin/mapserv HTTP/1.1" 500 1549 "-"
>> Gecko/20090824
>> One gets code 200, Two gets code 500.
>> error_log shows:
>> [Mon Sep 21 12:40:20 2009] [error] [client 98.200.238.238] Premature end
>> of
>> script headers: mapserv
>> mapserv -v
>> MapServer version 5.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=ICONV
>> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
>> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=THREADS INPUT=EPPL7
>> INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>> MapServer is now configured for
>> -------------- Compiler Info -------------
>> C compiler: gcc -O2 -fPIC -Wall
>> C++ compiler: g++ -O2 -fPIC -Wall
>> Debug: -DNEED_NONBLOCKING_STDERR
>> Generic NINT:
>> -------------- Renderer Settings ---------
>> zlib support: -DUSE_ZLIB
>> png support:
>> palette rgba png support:
>> jpeg support:
>> iconv support: -DUSE_ICONV
>> AGG support:
>> AGG Freetype support:
>> Ming(flash) support:
>> PDFLib support:
>> -------------- Support Libraries ---------
>> Proj.4 support: -DUSE_PROJ
>> Libxml2 support: -DUSE_LIBXML2
>> FriBidi support:
>> Curl support: -DUSE_CURL
>> FastCGI support:
>> Threading support: -DUSE_THREAD
>> GEOS support:
>> -------------- Data Format Drivers -------
>> native tiff support:
>> PostGIS support: -DUSE_POSTGIS
>> EPPL7 support: -DUSE_EPPL
>> ArcSDE support:
>> OGR support: -DUSE_OGR
>> GDAL support: -DUSE_GDAL
>> Oracle Spatial support:
>> -------------- OGC Services --------------
>> WMS Server: -DUSE_WMS_SVR
>> WMS Client: -DUSE_WMS_LYR
>> WFS Server: -DUSE_WFS_SVR
>> WFS Client: -DUSE_WMS_LYR
>> WCS Server: -DUSE_WCS_SVR
>> SOS Server:
>> -------------- MapScript -----------------
>> PHP MapScript: yes
>> Installation: Fedora 7, Linux Apache/2.2.8
>> Does anyone have any thoughts about where I may start looking for clues?
>> Thank you,
>> Ted S.
> mapserver-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/mapserver-files-to-subdomain-results-in-500-Internal-Server-Error-when-mapserv-executable-accessed-tl-tp3687559p3689025.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
