[mapserver-users] mapserver files to subdomain results
in '500Internal
Server Error' when mapserv executable accessed through url
Daniel Morissette
dmorissette at mapgears.com
Tue Sep 22 15:49:51 EDT 2009
Ted Spradley wrote:
> Then I tried setting the environment variable by adding 'SetEnv
> LD_LIBRARY_PATH /usr/local/lib'
> to the /var/www/vhosts/domain/conf/httpd.include file as follows:
> <VirtualHost xxx.xxx.xxx.xx:80>
> ServerName maps.domain.com:80
> SuexecUserGroup snoogadmin psacln
> ServerAdmin "admin at domain.com"
> DocumentRoot /var/www/vhosts/domain.com/subdomains/maps/httpdocs
> CustomLog /var/www/vhosts/domain.com/statistics/logs/access_log
> plesklog
> ErrorLog /var/www/vhosts/domain.com/statistics/logs/error_log
> ScriptAlias /cgi-bin/ /var/www/cgi-bin/
> SetEnv LD_LIBRARY_PATH /usr/local/lib
> and restarted Apache, but with the same result of '500 Internal Server
> Error'.
You also need to tell Apache to pass the env var to the CGI environment
using PassEnv:
PassEnv LD_LIBRARY_PATH
Daniel
Daniel Morissette
http://www.mapgears.com/
