[mapserver-users] Upgrading ms4w setup.exe installer - continued
Jeff McKenna jmckenna at gatewaygeomatics.com
Tue Sep 22 07:31:03 EDT 2009
Rahkonen Jukka wrote:
> Hi,
> Just the same for me and our Windows server 2003, SP2.  I unzipped
> everything to d:\ms4w as usual, but Apache does not start.  Error
> message is “The system cannot execute the specified program”.
> -Jukka Rahkonen-
>     *Lähettäjä:* mapserver-users-bounces at lists.osgeo.org
>     [mailto:mapserver-users-bounces at lists.osgeo.org] *Puolesta *Lars
>     Westerlind
>     *Lähetetty:* 22. syyskuuta 2009 12:30
>     *Vastaanottaja:* Lars Westerlind; mapserver-users at lists.osgeo.org
>     *Aihe:* SV: [mapserver-users] Upgrading ms4w setup.exe installer -
>     continued
>     Current position:
>     On my Windows server 2003, SP2, MS4W 3.0 simply does not install.
>     I make a new download of the  zipfile and expand it as C:/ms4w … I
>     copy msvcr90.dll from cgi-bin to a directory in the “path”. Still, I
>     get “The system cannot execute the specified program”.
>     Using dependency walker on httpd.exe, I get errors on loading
>     IESHIMS.DLL and WER.DLL which both are probably not required
>     (delay-load). And msvcr90 was fixed with above action. Still, this
>     program says
>     *Error: The Side-by-Side configuration information for
>     "c:\ms4w\apache\bin\HTTPD.EXE" contains errors. This application has
>     failed to start because the application configuration is incorrect.
>     Reinstalling the application may fix this problem (14001).*
>     "c:\ms4w\apache\bin\LIBHTTPD.DLL" contains errors. This application
>     has failed to start because the application configuration is
>     incorrect. Reinstalling the application may fix this problem (14001).*
>     "c:\ms4w\apache\bin\LIBAPRUTIL-1.DLL" contains errors. This
>     application has failed to start because the application
>     configuration is incorrect. Reinstalling the application may fix
>     "c:\ms4w\apache\bin\LIBAPRICONV-1.DLL" contains errors. This
>     "c:\ms4w\apache\bin\LIBAPR-1.DLL" contains errors. This application
>     *Warning: At least one delay-load dependency module was not found.*
>     I’ve tried with the standard looks of the configuration from the
>     download, and know nothing about any “application configuration”
>     that could be wrong.
>     The download works well on my Windows XP-system, and the old ms4w
>     installed using the windows installer works well on this Windows
>     2003 server.
Lars & Jukka,
Would you mind posting your issues on the MS4W-users mailing list so all
users can follow along?  (join at
http://lists.maptools.org/mailman/listinfo/ms4w-users)  thanks.
-jeff
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
