SV: [mapserver-users] Upgrading ms4w setup.exe installer - continued
Lars Westerlind
lars.westerlind at enera.se
Tue Sep 22 08:29:38 EDT 2009
Done. Topic moved to the other list
/Lars
-----Ursprungligt meddelande-----
Från: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] För Jeff McKenna
Skickat: 22 September 2009 13:31
Till: mapserver-users at lists.osgeo.org
Ämne: Re: [mapserver-users] Upgrading ms4w setup.exe installer - continued
Rahkonen Jukka wrote:
> Hi,
> Just the same for me and our Windows server 2003, SP2. I unzipped
> everything to d:\ms4w as usual, but Apache does not start. Error
> message is "The system cannot execute the specified program".
> -Jukka Rahkonen-
> *Lähettäjä:* mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] *Puolesta *Lars
> Westerlind
> *Lähetetty:* 22. syyskuuta 2009 12:30
> *Vastaanottaja:* Lars Westerlind; mapserver-users at lists.osgeo.org
> *Aihe:* SV: [mapserver-users] Upgrading ms4w setup.exe installer -
> continued
> Current position:
> On my Windows server 2003, SP2, MS4W 3.0 simply does not install.
> I make a new download of the zipfile and expand it as C:/ms4w ... I
> copy msvcr90.dll from cgi-bin to a directory in the "path". Still, I
> get "The system cannot execute the specified program".
> Using dependency walker on httpd.exe, I get errors on loading
> IESHIMS.DLL and WER.DLL which both are probably not required
> (delay-load). And msvcr90 was fixed with above action. Still, this
> program says
> *Error: The Side-by-Side configuration information for
> "c:\ms4w\apache\bin\HTTPD.EXE" contains errors. This application has
> failed to start because the application configuration is incorrect.
> Reinstalling the application may fix this problem (14001).*
> "c:\ms4w\apache\bin\LIBHTTPD.DLL" contains errors. This application
> has failed to start because the application configuration is
> incorrect. Reinstalling the application may fix this problem (14001).*
> "c:\ms4w\apache\bin\LIBAPRUTIL-1.DLL" contains errors. This
> application has failed to start because the application
> configuration is incorrect. Reinstalling the application may fix
> "c:\ms4w\apache\bin\LIBAPRICONV-1.DLL" contains errors. This
> "c:\ms4w\apache\bin\LIBAPR-1.DLL" contains errors. This application
> *Warning: At least one delay-load dependency module was not found.*
> I've tried with the standard looks of the configuration from the
> download, and know nothing about any "application configuration"
> that could be wrong.
> The download works well on my Windows XP-system, and the old ms4w
> installed using the windows installer works well on this Windows
> 2003 server.
Lars & Jukka,
Would you mind posting your issues on the MS4W-users mailing list so all
users can follow along? (join at
http://lists.maptools.org/mailman/listinfo/ms4w-users) thanks.
-jeff
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
