[mapserver-users] Point in polygon
truongpm truong_pham_minh at yahoo.com
Wed Sep 23 07:40:32 EDT 2009
Thanks Steve, I trying with MySWL Spatial extension.
Steve Lime wrote:
> I know if you were in PostGIS you could do a spatial join of sorts. That
> is join
> each commune polygon with the points it contains (or just a count) based
> on
> an intersection operator. I don't know if that's possible with MySQL or
> not.
> You could also consider pre-processing your data if it doesn't change
> often.
> A simple MapScript script could be used like so:
>   - for each commune geom
>     - build a shapeObj
>     - do a queryByShape() against the point data
>     - store the count in the appropriate commune record
> You might have to pull the park data into something MapServer can query.
> With the count in the commune data you could easily classify on that
> attribute. You'd see better performance as well.
> Some ideas anyway.
> Steve
>>>> truongpm <truong_pham_minh at yahoo.com> 09/22/09 2:13 AM >>>
> Hi list,
> I have a problem with defined a point is in which polygon. For example, a
> map have 2 layer: commune-polygon; park - point.
> I want to layout color of polygon (each commune) depend on amount of point
> in this polygon.
> I done with query polygon from mySQL database, layout its color base on an
> attribute in database.
> My question is that how could i know which polygon that point inside???
> Thanks for your attentions and sorry about my language skills.
> http://n2.nabble.com/Point-in-polygon-tp3690813p3690813.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Point-in-polygon-tp3690813p3699021.html
