[mapserver-users] OSOpenData
Brent Fraser bfraser at geoanalytic.com
Mon Apr 5 10:28:12 EDT 2010
Lester,
   To get started, assuming you have downloaded the data, you could use GDAL's
ogrtindex (or gdaltindex for raster) to create a mapserver TILEINDEX of the
thousands of map tiles...
   There will be lots of other issues:
	- for a particular dataset, are all the .dbf files the same? (a requirement for
a TILEINDEX)
	- is there metadata describing the attributes? (to make the CLASS creation easier)
	- etc
The desired quality of your output will determine how far you'll have to dig
into the data...
Best Regards,
Brent Fraser
Lester Caine wrote:
> Anybody playing with the maps that OS has no made available. In
> particular anybody looked at how to build a map file for the thousands
> of 10k map tiles?
> There is a bit of a bug in that data in that a few grid squares have be
> processed with lower case file names, while the core info files list
> them in upper case but at least they are there.
