[mapserver-users] Strange Behaviour with getFeature usingv POST method and more than one typename
David Alda Fernandez de Lezea dalda at ikt.es
Tue Apr 13 07:22:48 EDT 2010
Jukka,
Thanks for your response. I made the test you told me and it worked (buff, what a relief!!). I've made several tests with different number of features to get (1, 5, 10, 50), and I get the expected response. I would like to test it using a PostGis Layer, but I can't find the way to make it work (I think is the definition of the layer). It should be something like this:
LAYER
	NAME "ParcelasPG"
	STATUS ON
	PROJECTION
		"init=epsg:23030"
	END
	METADATA
		"wfs_title" "Parcelas Sigpac 2009 - Shape" ## REQUIRED
		"wfs_abstract" "Parcelas"
		"wfs_name" "ParcelasPG"
		"wfs_srs" "EPSG:23030" ## Recommended
		"gml_featureid" "gid" ## REQUIRED
		"gml_exclude_items"         "all"
	END
	TYPE POLYGON
	CONNECTIONTYPE postgis
	CONNECTION "user=postgres password=1111 dbname=LANDAGIS_V3 host=localhost"
	PROCESSING "CLOSE_CONNECTION=DEFER"
	DATA "the_geom FROM tb_parcelas_geo using unique gid using SRID=23030"
	CLASS
		STYLE
			COLOR 255 123 0
			OUTLINECOLOR 0 0 0
		END
	END
END
On the other subject, it seems that there's a problem with Oracle spatial. What could be happening??Is there a way to see what queries are sent to Oracle Spatial, because maybe that's the problem, the queries are badformed??
Thanks for your help.
-----Mensaje original-----
De: Rahkonen Jukka [mailto:Jukka.Rahkonen at mmmtike.fi]
Enviado el: martes, 13 de abril de 2010 11:33
Para: David Alda Fernandez de Lezea; mapserver-users at lists.osgeo.org
Asunto: Re: [mapserver-users] Strange Behaviour with getFeature usingPOSTmethod and more than one typename
I created a WFS service from a scratch by using shapefile as a data source. I made a similar query as you did, GET with FILTER having four different numbers in PropertyIsEqualTo sections and OR condition. Mapserver version 5.2.1 gives me a correct result both with WFS 1.0.0 and 1.1.0.
Now we know that Mapserver can do it but we do not know yet why it does not do it for you. I would suggest you to repeat my test by converting some part of your Oracle data into shapefile and making a new feature type out of that. Test if your four-GID filter works all right against shapefile. If yes, then it might be something Oracle specific.
Copy-pasting your request makes me think that there may be an extra white space here:
"<PropertyName>> GID</PropertyName><Literal>160<"
Check it first.
-Jukka Rahkonen-
David Alda Fernandez de Lezea wrote:
> Hi again,
> If I use GET Method and FILTER parameter in URL something like:
> http://192.168.1.65/cgi-bin/mapserv.exe?map=../htdocs/MFD/ejem
plo_wfs.map&SERVICE=WFS&VERSION=1.1.0> &REQUEST=GetFeature&TYPENAME=PoligonosSigpac&MAXFEATURES=1000&
FILTER=<Filter><Or><PropertyIsEqualTo><PropertyName>> GID</PropertyName><Literal>16</Literal></PropertyIsEqualTo><Pr
> opertyIsEqualTo><PropertyName>GID</PropertyName><Literal>29</L
iteral></PropertyIsEqualTo><PropertyIsEqualTo><PropertyName>>
iteral>GID</PropertyName><Literal>160</Literal></PropertyIsEqualTo><P
> ropertyIsEqualTo><PropertyName>GID</PropertyName><Literal>529<
/Literal></PropertyIsEqualTo></Or></Filter>
> I get again the first two features OK but the following ones are
> repeated, they are equal to the GID=29. Is this a kind of bug or
> something like that? I don't understand it. Maybe is something wrong
> with my layer:
> LAYER
> 	NAME "PoligonosSigpac"
> 	PROJECTION
> 		"init=epsg:23030"
> 	END
> 	METADATA
> 		"wfs_title" "Poligonos Sigpac 2009" ## REQUIRED
> 		"wfs_abstract" "Poligonos"
> 		"wfs_name" "PoligonosSigpac"
> 		"wfs_geometry_element_name" "MS_GEOMETRY"
> 		"wfs_extent"          "463498.785171405
> 4702415.34945634 603167.123773832 4811812.82264918"
> 	END
> 	TYPE POLYGON
> 	CONNECTIONTYPE oraclespatial
> 	CONNECTION "admcarto/admcarto at ORA10GEX"
> 	DATA "GEOMETRY FROM (SELECT * FROM GX_SIGPAC_POLIGONOS) USING UNIQUE
> gid SRID 82337" #todo el sigpac
> 	DUMP TRUE ## REQUIRED
> 	CLASS
> 		NAME "Poligonos"
> 			STYLE
> 				OUTLINECOLOR 255 255 255
> 			END
> 		TEMPLATE "ttt_query.html"
> 	END
> 	STATUS ON
> END # Layer
> Or Maybe at mapfile level:
> NAME "wfs_server"
> 		STATUS ON
> 		EXTENT 460000 4710000 610000 4820000
> 		PROJECTION
> 			"init=epsg:23030"
> 		END
> 		SHAPEPATH "shapes/"
> 		FONTSET "misc/fonts/fonts.txt"
> 		SYMBOLSET "misc/symbols/symbols.sym"
> 		IMAGETYPE "image/png; mode=24bit"
> 		IMAGECOLOR 255 255 255
> 		UNITS METERS
> 		DEBUG ON
> 		CONFIG "MS_ERRORFILE"
> "C:/ms4w/Apache/htdocs/MFD/tmp/ms_wfs.log"
> 		DEBUG 5
> 		WEB
> 			IMAGEPATH "MFD/tmp/"
> 			IMAGEURL "tmp/"
> 			METADATA
> 				"wfs_title" "IKT WFS Server" ## REQUIRED
> 				"wfs_abstract" "Servicio de
> mapas WFS de IKT Nekazal Teknologia. Powered by Apache and UMN
> MapServer" ## REQUIRED
> 				"wfs_onlineresource"
> "http://192.168.1.65/cgi-bin/mapserv.exe?map=../htdocs/MFD/eje
mplo_wfs.map&" ## Recommended
> 				"wfs_keywordlist"
> "IKT,Euskadi,Mapas Euskadi"
> 				"wfs_fees"		"none"
> 				"wfs_accessconstraints"
> "Ninguna"
> 				"ows_contactorganization"
> "http://www.ikt.es"
> "MS_GEOMETRY"
> 			END
> 		END
> Please, any idea is appreciated. Hope someone can help. I can't
> believe MapServer can't do this, it's impossible.
> Thanks.
> De: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] En nombre de David
> Alda Fernandez de Lezea Enviado el: lunes, 12 de abril de 2010 13:20
> Para: mapserver-users at lists.osgeo.org
> Asunto: RE: [mapserver-users] Strange Behaviour with getFeature using
> Assefa,
> Thanks for your response. I had that configured in the waye you told
> me this is what I get:
> [Fri Apr 09 11:24:45 2010].725000 CGI Request 1 on process
> 1948 [Fri Apr 09 11:24:46 2010].37000 mapserv request processing time
> (msLoadMap not incl.): 0.312s [Fri Apr 09
> 11:24:46 2010].37000 msFreeMap(): freeing map at 015D60B8.
> > You should be able to check then the query sent to the
> oracle db and that might give your more hints.
> Where I can view the query sent to Oracle??
> Thanks.
> De: Yewondwossen Assefa [mailto:yassefa at dmsolutions.ca] Enviado el:
> viernes, 09 de abril de 2010 14:19
> CC: mapserver-users at lists.osgeo.org
> David,
>  You could possibly get more hints if you put you map in debug mode
> and see the logs. You can add something like this in your map:
> CONFIG  "MS_ERRORFILE" "f:/tmp/ms_error.log"
> DEBUG 5
> You should be able to check then the query sent to the oracle db and
> regards,
> > Hi list,
> > I'm having a strange behaviour when receiving data from
> getFeature request. I prepare a request that is intended to mark some
> parcels from two different layers (these layers are stored in Oracle
> Spatial). The request looks like:
> > <?xml version="1.0" ?>
> > <wfs:GetFeature service="WFS" version="1.1.0"
> outputFormat="text/xml;
> > subtype=gml/3.1.1" xmlns:wfs="http://www.opengis.net/wfs"
> > xmlns:ogc="http://www.opengis.net/ogc"
> > xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> > xsi:schemaLocation="http://www.opengis.net/wfs
> ../wfs/1.1.0/WFS.xsd">
> > <wfs:Query typeName="RecintosSigpac"> <ogc:Filter> <ogc:Or>
> <ogc:And>
> <PropertyIsEqualTo><PropertyName>PROVINCIA</PropertyName><Literal>1</L
> <PropertyIsEqualTo><PropertyName>MUNICIPIO</PropertyName><Literal>1</L
> <PropertyIsEqualTo><PropertyName>POLIGONO</PropertyName><Literal>1</Li
> <PropertyIsEqualTo><PropertyName>PARCELA</PropertyName><Literal>1</Lit
> <PropertyIsEqualTo><PropertyName>RECINTO</PropertyName><Literal>1</Lit
> > </ogc:And>
> > <ogc:And>
> <PropertyIsEqualTo><PropertyName>PARCELA</PropertyName><Literal>20</Li
> > </ogc:And>
> > <ogc:And>
> <PropertyIsEqualTo><PropertyName>PARCELA</PropertyName><Literal>24</Li
> > </ogc:And>
> > </ogc:Or>
> > </ogc:Filter>
> > </wfs:Query>
> > <wfs:Query typeName="ParcelasSigpac"> <ogc:Filter> <ogc:Or>
> > <ogc:And>
> <PropertyIsEqualTo><PropertyName>PARCELA</PropertyName><Literal>29</Li
> > </ogc:And>
> > <ogc:And>
> <PropertyIsEqualTo><PropertyName>PARCELA</PropertyName><Literal>5</Lit
> > </ogc:And>
> > </ogc:Or>
> > </ogc:Filter>
> > </wfs:Query>
> > </wfs:GetFeature>
> > All the features that I want to mark using these filters
> are unique rows in Oracle Spatial. Using my Ajax app I get the
> following response:
> > <?xml version='1.0' encoding="ISO-8859-1" ?> <wfs:FeatureCollection
> >    xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
> >    xmlns:gml="http://www.opengis.net/gml"
> xsi:schemaLocation="http://mapserver.gis.umn.edu/mapserver
plo_wfs.map&amp;SERVICE=WFS&amp;VERSION=1.1.0> &amp;REQUEST=DescribeFeatureType&amp;TYPENAME=RecintosSigpac,P
> arcelasSigpac&amp;OUTPUTFORMAT=text/xml; subtype=gml/3.1.1
> http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
> >       <gml:boundedBy>
> >       	<gml:Envelope srsName="EPSG:23030">
> >       		<gml:lowerCorner>538881.736860
> 4744342.676060</gml:lowerCorner>
> >       		<gml:upperCorner>539514.702532
> 4744971.618431</gml:upperCorner>
> >       	</gml:Envelope>
> >       </gml:boundedBy>
> >     <gml:featureMember>
> >       <ms:RecintosSigpac gml:id="RecintosSigpac.752">
> >         <gml:boundedBy>
> >         		<gml:lowerCorner>539098.554563
> 4744632.941135</gml:lowerCorner>
> >         		<gml:upperCorner>539191.352464
> 4744726.952445</gml:upperCorner>
> >         	</gml:Envelope>
> >         </gml:boundedBy>
> >         <ms:msGeometry>
> >           <gml:Polygon srsName="EPSG:23030">
> >             <gml:exterior>
> >               <gml:LinearRing>
> >                 <gml:posList srsDimension="2">539146.378383
> 4744724.433931 539145.235158 4744724.343655 539141.209291
> 4744724.134593 539098.862296 4744721.948469 539098.790865
> 4744711.615815 539098.554563 4744677.257422 539100.133554
> 4744665.742677 539101.989421 4744645.274892 539102.338824
> 4744636.815604 539147.216698 4744634.836696 539183.793353
> 4744632.941135 539191.352464 4744725.909256 539176.751878
> 4744726.952445 539160.884500 4744725.549674 539146.378383
> 4744724.433931 </gml:posList>
> >               </gml:LinearRing>
> >             </gml:exterior>
> >           </gml:Polygon>
> >         </ms:msGeometry>
> >       </ms:RecintosSigpac>
> >     </gml:featureMember>
> >     <gml:featureMember>
> >         <gml:boundedBy>
> >         	</gml:Envelope>
> >         </gml:boundedBy>
> >         <ms:msGeometry>
> >             <gml:exterior>
> >               <gml:LinearRing>
> >               </gml:LinearRing>
> >             </gml:exterior>
> >           </gml:Polygon>
> >         </ms:msGeometry>
> >     <gml:featureMember>
> >       <ms:RecintosSigpac gml:id="RecintosSigpac.780">
> >         <gml:boundedBy>
> >         		<gml:lowerCorner>539140.476604
> 4744723.079992</gml:lowerCorner>
> >         		<gml:upperCorner>539239.310392
> 4744825.870297</gml:upperCorner>
> >         	</gml:Envelope>
> >         </gml:boundedBy>
> >         <ms:msGeometry>
> >             <gml:exterior>
> >               <gml:LinearRing>
> >                 <gml:posList srsDimension="2">539210.760749
> 4744825.870297 539171.605414 4744812.932158 539154.900802
> 4744810.658958 539151.793893 4744810.241026 539150.884920
> 4744803.887571 539149.435868 4744793.751862 539144.504835
> 4744774.483491 539140.476604 4744745.790917 539141.570279
> 4744729.302770 539144.916268 4744728.632982 539155.283284
> 4744730.181283 539174.221816 4744732.271720 539213.767798
> 4744726.008999 539214.713582 4744725.893379 539232.282920
> 4744723.079992 539239.310392 4744781.827717 539208.870828
> 4744783.739315 539209.136859 4744799.555691 539209.910262
> 4744816.473342 539210.760749 4744825.870297 </gml:posList>
> >               </gml:LinearRing>
> >             </gml:exterior>
> >           </gml:Polygon>
> >         </ms:msGeometry>
> >     <gml:featureMember>
> >       <ms:ParcelasSigpac gml:id="ParcelasSigpac.432">
> >         <gml:boundedBy>
> >         		<gml:lowerCorner>539350.511939
> 4744673.714232</gml:lowerCorner>
> >         	</gml:Envelope>
> >         </gml:boundedBy>
> >         <ms:msGeometry>
> >             <gml:exterior>
> >               <gml:LinearRing>
> >                 <gml:posList srsDimension="2">539491.015879
> 4744792.082294 539475.782392 4744815.126130 539474.642472
> 4744816.850943 539474.056299 4744817.555015 539460.451809
> 4744853.928462 539454.143305 4744873.207102 539440.629731
> 4744926.019638 539430.716698 4744943.313585 539413.952425
> 4744959.898107 539411.273518 4744964.881346 539407.646330
> 4744971.618431 539406.476289 4744971.434873 539406.366823
> 4744971.415630 539405.504687 4744971.280377 539358.907641
> 4744964.079030 539357.908645 4744963.924384 539357.819670
> 4744963.914567 539352.263608 4744963.054354 539351.935157
> 4744963.005934 539350.511939 4744962.783705 539352.673948
> 4744946.385464 539357.193238 4744935.734641 539371.562447
> 4744905.629881 539384.165455 4744865.843680 539397.369264
> 4744840.768116 539413.956573 4744791.742981 539415.753731
> 4744775.705698 539422.336088 4744776.767313 539431.436383
> 4744778.243618 539450.177203 4744778.946742 539457.925869
> 4744776.068340 539458.492779 4744775.140756 539466.401928
> 4744762.191662 539488.212759 4744674.250571 539488.822495
> 4744674.216836 539498.564357 4744673.714232 539514.702532
> 4744675.677836 539513.744624 4744680.289272 539490.550025
> 4744792.107546 539491.015879 4744792.082294 </gml:posList>
> >               </gml:LinearRing>
> >             </gml:exterior>
> >           </gml:Polygon>
> >         </ms:msGeometry>
> >       </ms:ParcelasSigpac>
> >     <gml:featureMember>
> >       <ms:ParcelasSigpac gml:id="ParcelasSigpac.470">
> >         <gml:boundedBy>
> >         		<gml:lowerCorner>538882.248073
> >         		<gml:upperCorner>539029.527193
> 4744453.228030</gml:upperCorner>
> >         	</gml:Envelope>
> >         </gml:boundedBy>
> >         <ms:msGeometry>
> >             <gml:exterior>
> >               <gml:LinearRing>
> >                 <gml:posList srsDimension="2">539029.513178
> 4744416.148626 539023.438691 4744440.204136 538915.364222
> 4744450.585437 538882.248073 4744453.228030 538882.331310
> 4744453.042333 538923.249964 4744365.347156 538933.462428
> 4744343.465189 538933.829894 4744342.676060 538941.133211
> 4744351.979153 538947.118409 4744358.193740 538960.350385
> 4744369.168664 538968.075321 4744372.945028 538971.325354
> 4744383.202584 539024.659247 4744412.165068 539029.527193
> 4744416.092856 539029.513178 4744416.148626 </gml:posList>
> >               </gml:LinearRing>
> >             </gml:exterior>
> >           </gml:Polygon>
> >         </ms:msGeometry>
> > </wfs:FeatureCollection>
> > The thing is that I get two features with the same 'id'
> (the two first features -> id 752) and same geodata and one of the
> requested parcels disappear (id-> 759). In DB table the id's are:
> > TABLE -> RecintosSigpac
> > Id  | PROVINCIA | MUNICIPIO | POLIGONO | PARCELA | RECINTO
> > 752 |	    1     |	    1     |    1     |	 20
> |	1
> > 759 |	    1     |	    1     |    1     |	 24
> |	1
> > 780 |	    1     |	    1     |    1     |	  1
> |	1
> > TABLE -> ParcelasSigpac
> > 432 |	    1     |	    1     |    1     |	 29
> > 470 |	    1     |	    1     |    1     |	  5
> > In other tests I've done it happens the same with the table
> ParcelasSigpac (the same case but changing roles), so maybe it's
> something I make wrong with the filters, or there's something special
> that I've to configure in the DB table.
> > Can someone, please, help me? It's really important because
> it's causing some troubles.
> > Thanks.
> > Un saludo,
> > David Alda Fernández de Lezea
> > Lurralde eta Biodibertsitate Saila / Dpto. de Territorio y
> > Biodiversidad
> > IKT
> > Granja Modelo s/n · 01192 · Arkaute (Araba)
> > Tlfnos.: 945-00-32-95                         Fax: 945-00.32.90
> > email: dalda at ikt.es                                web: www.ikt.es
> > ············ _______________________________________________
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Assefa Yewondwossen
> Software Analyst
> Email: yassefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax:   (613) 565-0925
