[mapserver-users] multiple tileindex in a layer
Daniel Morissette
dmorissette at mapgears.com
Wed Apr 14 14:19:23 EDT 2010
Please send your replies via the list so that others who know better
than me about time support can help, and that other users who may have
similar problems can benefit from the answers when they search the archives.
Back to your last question, at first sight, what you have seems right,
and already combines the spatial index and time index. If you have
multiple images listed in your OMTO3ECOLUMNAMOUNTO3IDX layer that fit in
the requested map view and whose time attribute match the requested
time, then they should all be displayed.
If that doesn't work for you, then you will have to provide more
specific details to help us understand the exact problem.
Daniel
Peisheng Zhao wrote:
> Daniel,
> I also use postgis to generate time index, just like this:
> LAYER
> STATUS ON
> NAME "OMTO3ECOLUMNAMOUNTO3IDX"
> TYPE POLYGON
> CONNECTIONTYPE POSTGIS
> CONNECTION "dbname=mapserver password=anonymous user=anonymous
> port=5432"
> DATA "the_geom from omto3e_003_columnamounto3"
> METADATA
> "wms_title" "OMTO3e Total Ozone Solution Index"
> "ows_service" "none"
> END
> END
> LAYER
> NAME 'OMTO3e_ColumnAmountO3'
> TYPE RASTER
> STATUS ON
> PROCESSING "SCALE=50,700"
> DEBUG ON
> DUMP TRUE
> PROJECTION
> "init=epsg:4326" ##recommended
> END
> METADATA
> wms_title "Best Total Ozone Solution" ##required
> wms_timeextent "2004-08-30/2010-04-03"
> wms_srs "EPSG:4326"
> wms_timeitem "time"
> wms_timedefault "2010-04-03"
> wms_extent "-180.0 -90.0 180.0 90.0"
> END
> TILEITEM "location"
> TILEINDEX "OMTO3ECOLUMNAMOUNTO3IDX"
> END
> The TILEITEM "location" in database points to a data file. Do you
> mean "location" can point to an individual tiled image and MapServer can
> tile up couple of tiled images which have the same timestamp?
> Thanks.
> > Date: Wed, 14 Apr 2010 13:28:47 -0400
> > From: dmorissette at mapgears.com
> > To: mapserver-users at lists.osgeo.org
> > Subject: Re: [mapserver-users] multiple tileindex in a layer
> > > Daniel,
> > > Thank you for your answer.
> > > Generally, I use gdaltindex to create a shp file for spatial index. Do
> > > you mean I need to add a time attribute into this? Could you give
> me an
> > > example? Thanks a lot.
> > That's correct. You need to use a script or some manual method to add
> > and populate a time attribute in the DBF of the tileindex that was
> > created with gdaltindex.
> > I do not have an example, but you can read more about this approach here:
> > http://mapserver.org/ogc/wcs_server.html#spatio-temporal-indexes
> > It may be easier to fill in the time attributes if you use a PostGIS
> > table instead of a shapefile as the tileindex. There is an example of
> > the corresponding layer definitions here:
> http://mapserver.org/ogc/wms_time.html#example-of-wms-t-with-postgis-tile-index-for-raster-imagery
> > Daniel
> > Daniel Morissette
> > http://www.mapgears.com/
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> The New Busy is not the too busy. Combine all your e-mail accounts with
> Hotmail. Get busy.
> <http://www.windowslive.com/campaign/thenewbusy?tile=multiaccount&ocid=PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_4>
Daniel Morissette
