[mapserver-users] WFS GetFeature on Mapserver doesn't work
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Thu Apr 15 03:08:54 EDT 2010
Your GetCapabilities says:
</Capability>
<FeatureTypeList>
<Operations>
<Query/>
</Operations>
</FeatureTypeList>
Conclusion: feature type list is empty, so it does not make sense to continue to GetFeature before the layer settings are corrected and the layer appears in the GetCapabilities. Now, have a look at document http://mapserver.org/ogc/wfs_server.html and compare your mapfile with it. Most obvious reason for your failure is that your layer is missing DUMP TRUE.
-Jukka Rahkonen-
sunny74 wrote:
> Dear Friends,
> I am trying to get WFS working on Mapserver but both
> Getcapabilities and
> GetFeature are giving me errors.
> I am firing the following urls directly in the browser:
> Getcapabilities(map from DB )
> http://localhost:81/cgi-bin/mapserv.exe?map=d:/Delhi1_wfs_post
gres.map&SERVICE=WFS&VERSION=1.0.0&&REQUEST=GETcapabilities
> GetFeature
gres.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=GETfeature
> &typename=delhi_district
> delhi_district is the name of my table in the postgres DB.
> The o/p from Getcapabilities is:
> <WFS_Capabilities version="1.0.0" updateSequence="0"
> xsi:schemaLocation="http://www.opengis.net/wfs
> http://schemas.opengis.net/wfs/1.0.0/WFS-capabilities.xsd">
> MapServer version 5.2.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG
> SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
> SUPPORTS=THREADS
> SUPPORTS=GEOS SUPPORTS=RGBA_PNG INPUT=JPEG INPUT=POSTGIS INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE
> <Service>
> <Name>MapServer WFS</Name>
> <Title>GMap WFS Demo Server</Title>
> <OnlineResource>
gres.map&
> </OnlineResource>
> </Service>
> <Capability>
> <Request>
> <GetCapabilities>
> <DCPType>
> <HTTP>
> <Get
> onlineResource="http://localhost:81/cgi-bin/mapserv.exe?map=d:
/Delhi1_wfs_postgres.map&"/>
> </HTTP>
> </DCPType>
> <DCPType>
> <HTTP>
> <Post
> </HTTP>
> </DCPType>
> </GetCapabilities>
> <DescribeFeatureType>
> <SchemaDescriptionLanguage>
> <XMLSCHEMA/>
> </SchemaDescriptionLanguage>
> <DCPType>
> <HTTP>
> <Get
> </HTTP>
> </DCPType>
> <DCPType>
> <HTTP>
> <Post
> </HTTP>
> </DCPType>
> </DescribeFeatureType>
> <GetFeature>
> <ResultFormat>
> <GML2/>
> </ResultFormat>
> <DCPType>
> <HTTP>
> <Get
> </HTTP>
> </DCPType>
> <DCPType>
> <HTTP>
> <Post
> </HTTP>
> </DCPType>
> </GetFeature>
> </Request>
> </Capability>
> <FeatureTypeList>
> <Operations>
> <Query/>
> </Operations>
> </FeatureTypeList>
> <ogc:Filter_Capabilities>
> <ogc:Spatial_Capabilities>
> <ogc:Spatial_Operators>
> <ogc:Equals/>
> <ogc:Disjoint/>
> <ogc:Touches/>
> <ogc:Within/>
> <ogc:Overlaps/>
> <ogc:Crosses/>
> <ogc:Intersect/>
> <ogc:Contains/>
> <ogc:DWithin/>
> <ogc:BBOX/>
> </ogc:Spatial_Operators>
> </ogc:Spatial_Capabilities>
> <ogc:Scalar_Capabilities>
> <ogc:Logical_Operators/>
> <ogc:Comparison_Operators>
> <ogc:Simple_Comparisons/>
> <ogc:Like/>
> <ogc:Between/>
> </ogc:Comparison_Operators>
> </ogc:Scalar_Capabilities>
> </ogc:Filter_Capabilities>
> </WFS_Capabilities>
> The o/p from GetFeature is:
> <ServiceExceptionReport version="1.2.0"
> xsi:schemaLocation="http://www.opengis.net/ogc
> http://schemas.opengis.net/wfs/1.0.0/OGC-exception.xsd">
> <ServiceException code="InvalidParameterValue" locator="typename">
> msWFSGetFeature(): WFS server error. TYPENAME
> 'delhi_district' doesn't exist
> in this server. Please check the capabilities and
> reformulate your request.
> </ServiceException>
> </ServiceExceptionReport>
> So none of the outputs are proper
> My map File is as below:
> # Map file created from QGIS project file D:/QGIS
> 1.3/projects/delhi_trial.qqs.qgs
> # Edit this file to customize for your map interface
> # (Created with PyQgis MapServer Export plugin)
> MAP
> NAME Delhi1_postgres.map
> # Map image size
> SIZE 600 600
> UNITS dd
> SYMBOLSET 'C:\ms4w\Apache\htdocs\Delhi\Symbols.txt'
> FONTSET 'C:\ms4w\Apache\htdocs\Delhi\fonts.txt'
> EXTENT 76.507859 27.613907 78.439621 28.941223
> CONFIG "PROJ_LIB" "C:\ms4w\proj\nad"
> PROJECTION
> 'proj=longlat'
> 'ellps=WGS84'
> 'datum=WGS84'
> 'no_defs'
> END
> # Background color for the map canvas -- change as desired
> IMAGECOLOR 192 192 192
> IMAGEQUALITY 95
> IMAGETYPE png
> OUTPUTFORMAT
> NAME png
> DRIVER 'GD/PNG'
> MIMETYPE 'image/png'
> #IMAGEMODE PC256
> EXTENSION 'png'
> END
> # Legend
> LEGEND
> IMAGECOLOR 255 255 255
> STATUS ON
> KEYSIZE 18 12
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> END
> END
> # Web interface definition. Only the template parameter
> # is required to display a map. See MapServer documentation
> WEB
> # Set IMAGEPATH to the path where MapServer should
> # write its output.
> IMAGEPATH '/tmp/'
> # Set IMAGEURL to the url that points to IMAGEPATH
> # as defined in your web server configuration
> IMAGEURL '/tmp/'
> # WMS server settings
> METADATA
> "wfs_title" "GMap WFS Demo Server" ## REQUIRED
> "wfs_onlineresource"
> "http://localhost:81/cgi-bin/mapserv.exe?map=d:/Delhi1_wfs_pos
tgres.map" ##
> Recommended
> "wfs_srs" "EPSG:42304 EPSG:42101 EPSG:4269
> EPSG:4326" ##
> Recommended
> "wfs_request_method" "GET"
> 'queryable' 'true'
> "wfs_feature_info_mime_type" "gml"
> END
> #Scale range at which web interface will operate
> # Template and header/footer settings
> # Only the template parameter is required to display a map. See
> END
> LAYER
> CONNECTIONTYPE postgis
> CONNECTION "host=localhost dbname=DelhiDB
> user=postgres password=postgres
> port=5432"
> DATA "the_geom FROM delhi_district as foo USING
> UNIQUE gid USING
> SRID=4326"
> NAME 'delhi_district'
> TYPE POLYGON
> LABELITEM "polygon_nm"
> CLASSITEM "polygon_nm"
> METADATA
> "wfs_title" "WFS Map" ## REQUIRED
> "wfs_version" "1.0.0"
> "wfs_srs" "EPSG:4326"
> "wfs_typename" "delhi_district"
> "wfs_service" "WFS"
> "gml_featureid" "gid"
> END
> STATUS DEFAULT
> HEADER ../templates/Demo_header.html
> TEMPLATE ../templates/Demo_query_body1.html
> FOOTER ../templates/Demo_footer.html
> TRANSPARENCY 100
> PROJECTION
> 'proj=longlat'
> 'ellps=WGS84'
> 'datum=WGS84'
> 'no_defs'
> END
> CLASS
> EXPRESSION 'Ghaziabad'
> NAME 'Ghaziabad'
> GROUP 'Ghaziabad'
> STYLE
> SYMBOL "quadrat"
> SIZE 2
> OUTLINECOLOR 0 0 0
> COLOR 255 0 127
> END
> END
> CLASS
> EXPRESSION 'Gautam Buddha Nagar'
> NAME 'Gautam Buddha Nagar'
> GROUP 'Gautam Buddha Nagar'
> STYLE
> SYMBOL "quadrat"
> SIZE 2
> OUTLINECOLOR 0 0 0
> COLOR 0 0 255
> END
> END
> CLASS
> EXPRESSION 'North West'
> NAME 'North West'
> GROUP 'North West'
> STYLE
> SYMBOL "quadrat"
> SIZE 2
> OUTLINECOLOR 0 0 0
> COLOR 255 0 255
> END
> END
> CLASS
> EXPRESSION 'South West'
> NAME 'South West'
> GROUP 'South West'
> STYLE
> SYMBOL "quadrat"
> SIZE 2
> OUTLINECOLOR 0 0 0
> COLOR 255 170 0
> END
> END
> CLASS
> EXPRESSION 'West'
> NAME 'West'
> GROUP 'West'
> STYLE
> SYMBOL "quadrat"
> SIZE 2
> OUTLINECOLOR 0 0 0
> COLOR 85 170 255
> END
> END
> CLASS
> EXPRESSION 'New Delhi'
> NAME 'New Delhi'
> GROUP 'New Delhi'
> STYLE
> SYMBOL "quadrat"
> SIZE 2
> OUTLINECOLOR 0 0 0
> COLOR 170 170 0
> END
> END
> CLASS
> EXPRESSION 'East'
> NAME 'East'
> GROUP 'East'
> STYLE
> SYMBOL "quadrat"
> SIZE 2
> OUTLINECOLOR 0 0 0
> COLOR 170 85 255
> END
> END
> CLASS
> EXPRESSION 'North East'
> NAME 'North East'
> GROUP 'North East'
> STYLE
> SYMBOL "quadrat"
> SIZE 2
> OUTLINECOLOR 0 0 0
> COLOR 127 255 185
> END
> END
> CLASS
> EXPRESSION 'North'
> NAME 'North'
> GROUP 'North'
> STYLE
> SYMBOL "quadrat"
> SIZE 2
> OUTLINECOLOR 0 0 0
> COLOR 170 0 0
> END
> END
> CLASS
> EXPRESSION 'South'
> NAME 'South'
> GROUP 'South'
> STYLE
> SYMBOL "quadrat"
> SIZE 2
> OUTLINECOLOR 0 0 0
> COLOR 255 170 0
> END
> END
> CLASS
> EXPRESSION 'Faridabad'
> NAME 'Faridabad'
> GROUP 'Faridabad'
> STYLE
> SYMBOL "quadrat"
> SIZE 2
> OUTLINECOLOR 0 0 0
> COLOR 0 170 255
> END
> END
> CLASS
> EXPRESSION 'Gurgaon'
> NAME 'Gurgaon'
> GROUP 'Gurgaon'
> STYLE
> SYMBOL "quadrat"
> SIZE 2
> OUTLINECOLOR 0 0 0
> COLOR 0 255 170
> END
> END
> END
> END
> Why doesn't it work?
> Once this gets working I can invoke it using OL script.
> Thanks for your attention and efforts.
> http://n2.nabble.com/WFS-GetFeature-on-Mapserver-doesn-t-work-
> tp4905757p4905757.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
