[mapserver-users] Re: Mapscript c# VS 2010 framework 4 and memory
leaks
Tamas Szekeres
szekerest at gmail.com
Wed Apr 21 15:47:41 EDT 2010
Hi James,
I'm planning to exend http://vbkto.dyndns.org:1280/sdk with VS2010
builders, however it may require 1-2 weeks for me to compile all the
dependencies with VS2010 for Win32 and Win64.
Best regards,
Tamas
2010/4/21 James Perrins <james.perrins at gmail.com>:
> Hi,
> I've been struggling with memory errors doing fairly simple things
> (e.g. mapObj not populating properly - I could normally render a map
> image - but not work with the layers for example).
> This was in VS 2010 targeting .NET framework 4 - all appeared to work
> OK - in fact all did work OK within visual studio - but started to
> fall apart when run directly from a compiled exe.
> I tried a range of DLLs (including last stable version from
> http://vbkto.dyndns.org:1280/sdk/index.html) and used dependency
> walker to check all was in place.
> As a test I moved everything back to VS 2008 / 3.5 and it all worked -
> so I can only assume that maybe I need to get a version of teh
> MapScript c# dll built for framework 4 - does this make sense?
> I would dearly love to stay with 3.5 - but unfortunately we need a new
> component from 4.0
> Can anyone point me at a dll compiled for .NET 4 - or reassure me taht
> is should be relatively simple for me to tackle from the source!
> Many Thanks
> James
