[mapserver-users] Problem with Overlap image for WCS Request
Sarawut Ninsawat
sarawut.map at gmail.com
Tue Apr 27 10:03:22 EDT 2010
Hi Jukka,
Thank you very much. I check your post in mailing list. It is very
interesting.
However, I just wonder that it will work for WCS time tiling which has a
time attribute in tile polygon. Because I will allow client to request
both of Spatial and Temporal subset.
I think I may try by replace a tif filename with vrt filename, maybe it
will work. Any comment is appreciate.
Sarawut
Sara
Rahkonen Jukka wrote:
> Hi,
> Use gdalbuildvrt utility for creating a virtual mosaic of your original files and use the resulting .vrt file as input for Mapserver. It looks like normal tileindex system does not work correctly with WCS. I have written some mails about this last week, have a look at the archives.
> -Jukka Rahkonen-
> Sarawut Ninsawat wrote:
>> Hi folks,
>> I have setup a WCS server for Spatial/Temporal tiling. It is work well
> when I have only one scene (same spatial extent) for multiple temporal
> image.
>> But when there is two image scene (in my case MOD11A1 scene h28v05 and
> h29v05), there is a problem when BBOX request is in overlap area between
> two scenes. As the output is composed of null value of scene h29v05 (in
> that area of scene h28v05, there is a observed data).
>> I just wonder that there is any technique to make mapserver can do a
> composite or mosaicking etc. of two scene for output. Please advise me
> any idea or it is not complaint to WCS specification ?
>> I just thinking the possibility about "Title index Polygon only valid
> area of image" ?
>> Best regards
>> Sarawut
> __
