[mapserver-users] Re: WMS and tiles cutting off
Lime, Steve D (DNR) Steve.Lime at state.mn.us
Thu Apr 29 14:54:02 EDT 2010
So use two layers. One for the background, use tilecache for that. Then use an untiled wms/mapserver layer for the overlayed points. - Steve
________________________________________
From: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] On Behalf Of Adam Eskreis [aeskreis at gmail.com]
Sent: Thursday, April 29, 2010 1:24 PM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Re: WMS and tiles cutting off
I have thought about using tilecache with metatiling, however there is a caveat about this map that i forgot to mention in my main post, and it has to do with that "categories" parameter.  Basically, each point/symbol on the map has an associated category in the database backend.  I am using mapserver/WMS parameters to change the categories which are called.  Each time the user selects a category, only the points in that category are shown.  My query in the mapfile looks something like thi:
SELECT point_geom,gid,symbol,angle FROM mapdata WHERE category IN(%CATEGORIES%)";
And each time the user changes the categories, I use openlayers to merge new parameters, and input the new category values that should be used.  Is tilecache still useable if I have a system like this set up?
Thanks,
-Adam
On Thu, Apr 29, 2010 at 6:14 AM, kaipi <mapcollect at gmx.net<mailto:mapcollect at gmx.net>> wrote:
you can use  http://tilecache.org/ Tilecache   with the option metatiling
enabled. With metatiling enabled Tilecache will fetch larger tiles (eg.
4096x4096) from Mapserver and will cut them into smaller tiles (eg.
256x256). It will also increase performance because Mapserver does not need
to render tiles when they are already in cache.
kaipi
View this message in context: http://osgeo-org.1803224.n2.nabble.com/WMS-and-tiles-cutting-off-tp4978418p4979280.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapserver-users
