[mapserver-users] MINSCALEDENOM in layer units
Paco Regodón
mapserver at meteologica.es
Thu Apr 29 13:19:08 EDT 2010
MINSCALEDENOM is specified using map units.
I have a mapfile which can be requested using epsg:4326 (degrees) or
epsg:25830 (meters) using &map_projection=init=epsg:4236 or
&map_projection=init=epsg:25830.
The problem is that different scales are computed in both cases. Scale
varies between 3 and 100 when working with degrees, or between 5000 and
15.000.000.
One layer need to be represented only at certain ranges, but if i define
MINSCALEDENOM in degrees, it will fail to represent when using meters
and viceversa.
Is there any way i can define MINSCALEDENOM in layer's units instead of
map units? Something like a SCALEUNITS tag at layer level?
Thanks,
Paco Regodón
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100429/9a6cdd55/attachment.html
