[mapserver-users] Re: vector pdf output
Sumit Sharma
sumit321 at hotmail.com
Wed Aug 4 10:53:43 EDT 2010
Map does support vector PDF output. But be careful when you are using opacity
parameter in your layer. It seems that mapserver doesn't support
transparency in layer.
cario is supported by mapserver and I am using cario for generating pdf.
However my requirement was to create GeoPDF instead of normal PDF. for that
I am also taking help of Itext library ...
View this message in context: http://osgeo-org.1803224.n2.nabble.com/vector-pdf-output-tp5370130p5372877.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
