AW: [mapserver-users] shp/dbf file's name
Arnd Wippermann
arnd.wippermann at web.de
Sat Aug 21 17:37:24 EDT 2010
Hi Johan,
Haven't thought, that it is possible to style by joined fields. But your
example works. First I had some trouble to get the right syntax, and that
causes in MapServer crashes. But finally it worked! (Mapserver 5.2, 5.6.1)
With connection to shape and dbase folder
CONNECTIONTYPE OGR
CONNECTION "C:\mypath\BRD" #path were the data resides
DATA "SELECT * FROM DEU_adm1 LEFT JOIN DEU_adm1_EDICHTE ON DEU_adm1.HASC_1 =
DEU_adm1_EDICHTE.HASC_1"
With connection to shape and dbase by fullpath
CONNECTIONTYPE OGR
CONNECTION "C:\mypath\BRD\DEU_adm1.shp"
DATA "SELECT * FROM DEU_adm1 LEFT JOIN 'C:\mypath\BRD\EDICHTE.dbf'.EDICHTE
ON DEU_adm1.HASC_1 = EDICHTE.HASC_1"
But now I have the problem, that WMS GetFeatureInfo returns no results. The
queried features are the states of Germany, so I can't miss them. Can you
confirm that it should work.
Arnd
-----Ursprüngliche Nachricht-----
Von: mapserver-users-bounces at lists.osgeo.org
[mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag von Johan
Forsman
Gesendet: Freitag, 20. August 2010 18:22
An: Clément MONIER
Cc: mapserver-users at lists.osgeo.org
Betreff: RE: [mapserver-users] shp/dbf file's name
If I understand your question correctly you are attempting to do something
similar to what I have where I am coloring polygons in a shapefile based on
a numeric value stored in a frequently-updated CSV-file. As long as you have
a field in both files that you can join on it ought to work.
I used the OGR connection type as briefly discussed in a previous post,
http://www.mail-archive.com/mapserver-users@lists.umn.edu/msg13477.html
This is the type of syntax you appear to need:
CONNECTIONTYPE OGR
CONNECTION "/var/www/demodata/a.shp" //path to the shapefile DATA "SELECT
a.ID, b.NAME FROM a LEFT JOIN '/var/www/demodata/b.dbf'.b ON a.ID=b.ID"
In my case the LAYER section in the mapfile looks like this, where "FIPS" is
the field I join the files on.
LAYER
NAME 'parishes_on_boiladv'
CONNECTIONTYPE OGR
CONNECTION "myshapefile.shp"
DATA "SELECT * FROM myshapefile LEFT JOIN
'full_path_to_file_named_bwa.csv'.bwa ON myshapefile.FIPS = bwa.FIPS"
STATUS on
TYPE polygon
CLASSITEM "PercentageOut"
CLASS
EXPRESSION ([PercentageOut] > 0 AND [PercentageOut] <= 10)
NAME "0 - 10%"
STYLE
COLOR 56 168 0
END
END #class
(continues with several more classes).
Hope that helps,
Johan.
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-
> bounces at lists.osgeo.org] On Behalf Of Clément MONIER
> Sent: Friday, August 20, 2010 9:06 AM
> To: P Kishor
> Subject: RE: [mapserver-users] shp/dbf file's name
> > How would MapServer know which row in your external dbf file matches
> which row (aka feature) in your ShapeFile?
> > What if the external dbf file doesn't have the same number of rows
> > as
> the number of features in your ShapeFile?
> not really a problem as I'm able to generate dbf files with records in
> exactly same number and order as inside shp.
> > The dbf format is pretty primitive. Your best bet is to actually add
> > to
> your ShapeFile the data that is now in your external file. > It will
> also likely be faster.
> That's precisely what I can't do any more, since I'd like to join
> various kinds of time-related attributes on very static geometries.
> -----Message d'origine-----
> De : P Kishor [mailto:punk.kish at gmail.com] Envoyé : vendredi 20 août
> 2010 15:42 À : Clément MONIER Cc : mapserver-users at lists.osgeo.org
> Objet : Re: [mapserver-users] shp/dbf file's name
> On Fri, Aug 20, 2010 at 8:22 AM, Clément MONIER
> <Clement.MONIER at v-trafic.com> wrote:
> > Hi,
> > I would like to know if it's possible to draw geometries from a shp
> > file
> > according to attributes from a dbf
> > but with 2 files named differently.
> > For instance :
> > LAYER
> > NAME layer1
> > DATA shapefile1.shp
> > CLASS
> > EXPRESSION ([col1]=1)
> > STYLE
> > END
> > END
> > END
> > Where col1 is a field inside a file storing attributes
> > (dbf/csv/txt/.)
> but
> > not named shapefile1.dbf
> which row (aka feature) in your ShapeFile? What if the external dbf
> file doesn't have the same number of rows as the number of features in
> your ShapeFile?
> to your ShapeFile the data that is now in your external file. It will
> > I already tried to use the JOIN option but I think it's
> > inappropriate
> for my
> > purpose
> > since "You cannot use joins to affect the look of a map"
> > (http://mapserver.org/mapfile/join.html)
> > Thanks for your help !
> > Clément
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Puneet Kishor http://www.punkish.org
> Carbon Model http://carbonmodel.org
> Charter Member, Open Source Geospatial Foundation http://www.osgeo.org
> Science Commons Fellow,
> http://sciencecommons.org/about/whoweare/kishor
> Nelson Institute, UW-Madison http://www.nelson.wisc.edu
> - Assertions are politics; backing up assertions with evidence is
> science
> = _______________________________________________
