[mapserver-users] Re: Clipping returned WFS data to the requesting bounding box
Lime, Steve D (DNR) Steve.Lime at state.mn.us
Thu Dec 2 00:04:09 EST 2010
It's described at:
  http://mapserver.org/input/vector/postgis.html
It's a PostGIS-only hack. I'd advocate binding a few variables like extent and scale to expressions with a special syntax. For example, [_minx] or something like that. RFC 64 makes it much easier to extend expressions like this.
Steve
________________________________________
Sent: Tuesday, November 30, 2010 1:30 AM
To: Lime, Steve D (DNR)
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Re: Clipping returned WFS data to the    requesting bounding box
On 2010-11-29 22:11, Lime, Steve D (DNR) wrote:
> I'm not aware of any means to do this. If you're using PostGIS perhaps there's a way to use the !BOX! hack in conjunction with some of the analytical functions but it's a long shot... (see http://www.mail-archive.com/mapserver-users@lists.umn.edu/msg03006.html)
Quoting Paul Ramsey in the link above:
the evil "!BOX!" hack: In your data statement, if you compose it thusly:
DATA "the_geom from (select gid,the_geom from thetable where the_geom
&&  !BOX!) using unique gid"
When the postgis driver encounters the evil !BOX! it will replace it
with the current mapserver bounding box.
What exactly is the status of this demonic !BOX! hack? Is it described somewhere? Is the "current mapserver bounding box" queryable within MapServer itself?
Jan
