[mapserver-users] MSXML2.ServerXMLHTTP - POST not
GET- OpenLayers/Mapserver WFS
Donald Kerr
donald.kerr at dkerr.co.uk
Thu Dec 9 17:14:25 EST 2010
Here's my solution incorporating the binary read suggestion from Arnd
Wippermann over on users at openlayers.org:
MapServerUrl = "http://127.0.0.1:81/cgi-bin/mapserv.exe"
MapFile = "D:\mymapfilepath\mymapfile.map"
Server.ScriptTimeout = 360
Set xmlhttp = Server.CreateObject("MSXML2.ServerXMLHTTP")
Function BytesToText(strBytes)
strAsciiText = ""
lngLength = LenB(strBytes)
For lngIndex = 1 To lngLength
lngAsciiCode = AscB(MidB(strBytes, lngIndex, 1))
strAsciiText = strAsciiText & Chr(lngAsciiCode)
Next
BytesToText = strAsciiText
End Function
Select Case Request.ServerVariables("REQUEST_METHOD")
Case "GET"
strRequest = Request.QueryString
xmlhttp.open "GET", MapServerURL & "?MAP=" & MapFile & "&" &
strRequest, False
xmlhttp.send
Response.ContentType =
xmlhttp.getResponseHeader("content-type")
Response.BinaryWrite xmlhttp.responseBody
Case "POST"
lngByteSize = Request.TotalBytes
strRequest = BytesToText(Request.BinaryRead(lngByteSize))
xmlhttp.open "POST", MapServerURL & "?MAP=" & MapFile, false
xmlhttp.setRequestHeader "Content-Type", "application/xml;
charset=UTF-8"
xmlhttp.send strRequest
Response.write xmlhttp.responseText
End Select
Set xmlhttp = Nothing
Just set the MapServerUrl and the MapFile constants at the top of the code.
Works for both GETs and POSTs in my setup where the map baselayers are using
OpenLayers.Layer.WMS. I also have OpenLayers.Layer.WFS (uses GET) and
OpenLayers.Layer.Vector with OpenLayers.Protocol.WFS (uses POST). All are
working.
Many thanks.
Regards,
Donald
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Jeff McKenna
Sent: 09 December 2010 13:09
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] MSXML2.ServerXMLHTTP - POST not GET-
On 10-12-08 7:13 PM, Donald Kerr wrote:
> I am trying to port the setup so that it uses OpenLayers.Layer.Vector
> with OpenLayers.Protocol.WFS which uses POST as opposed to GET. This
> works fine with the setup that calls Apache directly on port 81 but
> does not work using MSXML2.ServerXMLHTTP in the asp page. When I say
> that it works fine with Apache, it returns valid GML but there's no
> geometry which, I believe, is sorted in MapServer 5.6.4 - I am using
> 5.6.3 in the latest MS4W package.
Note that MapServer version 5.6.5 is available through the MS4W
downloads page
(http://www.maptools.org/ms4w/index.phtml?page=downloads.html).
-jeff
Jeff McKenna
MapServer Consulting and Training Services http://www.gatewaygeomatics.com/
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
