[mapserver-users] displaying 3-band images
Brent Fraser
bfraser at geoanalytic.com
Thu Dec 9 17:39:59 EST 2010
David,
It sounds like image registration / coordinate system definition
problem. While it is not necessary for the image to have a coordinate
system defined (e.g as a geotiff tag) sine you can specify it in the
LAYER portion of the map file, I think it does need image registration
information, either as geotiff tags or in a .tfw (or .wld) file.
Specifying the EXTENT in the map file is only a layer "hint" to
mapserver, it does not specify the image registration.
I could be wrong; mayby there have been enhancements to use the
EXTENT or METADATA information.
What are your parameters for EPSG:43001?
Best Regards,
Brent Fraser
On 12/9/2010 3:13 PM, David Hildebrand wrote:
> Jukka:
> For now I am making a simple Mapserver CGI call
> (http://localhost/cgi-bin/mapserv.exe?map=MSTEST&layer=awifs&mode=map
> <http://localhost/cgi-bin/mapserv.exe?map=MSTEST&layer=awifs&mode=map>).
> This URL works for other raster layers but I have only had
> single-band images so far. In all cases the final map is in a
> projection different from the layer projection. Incidentally, when I
> point to a data source which I know does not exist I get the same
> behavior (no image and no error) even when I use CONFIG
> "ON_MISSING_DATA" "FAIL" in my map file.
> Thanks for your help.
> David V. Hildebrand
> Agriculture Financial Services Corporation
> (403) 782-8239
> www.afsc.ca <http://www.afsc.ca>
> This communication is intended for the use of the recipient to which
> it is addressed, and may contain confidential, personal and/or
> privileged information. Please contact Agriculture Financial Services
> Corporation immediately if you are not the intended recipient of this
> communication, and do not copy, distribute, or take action relying on
> it. Any communication received in error, or subsequent reply, should
> be deleted or destroyed. Please consider the environment before
> printing this email.
> -----Original Message-----
> From: Rahkonen Jukka [mailto:Jukka.Rahkonen at mmmtike.fi]
> Sent: Thursday, December 09, 2010 2:21 PM
> To: David Hildebrand
> Subject: Re: [mapserver-users] displaying 3-band images
> Hi,
> I will have a closer look tomorrow. What did you use for showing the
> image? Mapserver CGI call or WMS client or what? Could you send the
> request as well?
> Regards,
> -Jukka-
> -----Alkuperäinen viesti-----
> Lähettäjä: David Hildebrand [mailto:David.Hildebrand at afsc.ca]
> Lähetetty: to 9.12.2010 22:32
> Vastaanottaja: Rahkonen Jukka
> Aihe: RE: [mapserver-users] displaying 3-band images
> Jukka:
> I posted this to the mailing list but I don't think it got there
> because the body was too long so I'm sending it to you directly.
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101209/a543555f/attachment-0001.html
