[mapserver-users] deploying mapserver to render WFS which is
secured by OWS Proxy?
Stephan Holl
stephan.holl at intevation.de
Fri Dec 10 03:54:03 EST 2010
Hallo Jan,
Jan Berghoff-Flüel <janbf at webgis.de>, [20101209 - 15:01:37]
> I'm trying to retrieve WFS data from
> www.geoproxy.geoportal-th.de/geoproxy/services
> The problem is currently not the OWS Proxy itself but how to setup a
> mapfile to send
> the right POST or GET request including the sessionID.
I might be wrong but this seems impossible atm. If the proxy is
secured by http basic auth you could hand in the needed credentials
within the URL (untested though):
CONNECTION "https://user:pw@server.fqd:port/service?..."
Make sure you import the SSL-cert correctly in libcurls keystore (found
in the value of URL_CA_BUNDLE env-var.
See [1] for more details.
HTH
Stephan
[1] https://trac.osgeo.org/mapserver/ticket/3070
> 2010/12/9 Stephan Holl <stephan.holl at intevation.de>
> > Hallo Jan,
> > Jan Berghoff-Flüel <janbf at webgis.de>, [20101209 - 12:08:18]
> > > Hi,
> > > does anyone have experiences deploying mapserver to render a WFS
> > > which is secured by OWS Proxy?
> > > The problem is how to provide the dynamicly created sessionID to
> > > the OWS Proxy to retrieve WFS data,
> > > especially when using POST method.
> > > Is this possible at all?
> > > Any hints are appreciated. Thanks in advance.
> > Which OWS Proxy are you referring to?
> > Best
> > Stephan
> > Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508
> > 3663 Intevation GmbH, Neuer Graben 17, 49074 OS | AG Osnabrück -
> > HR B 18998 Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr.
> > Jan-Oliver Wagner
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663
Intevation GmbH, Neuer Graben 17, 49074 OS | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101210/f999bd53/signature-0001.bin
