Re: [mapserver-users] ‘mode=map’ with WMC of dynamic <Layer> failing with getString() error
Wim Vanbelle
wimvanbelle at gmail.com
Mon Dec 13 03:04:38 EST 2010
I haven't done something similar to what you are trying to do, but at first
glance i see a space standing between vector’ and END.
Did you try replacing the space with %20?
Just a thought :).
On 11 December 2010 14:49, Jeff McKenna <jmckenna at gatewaygeomatics.com>wrote:
> On 10-12-10 5:57 PM, myOpenLayersUName wrote:
>> And, maybe I have, but now I’m completely stuck. At this point, I have the
>> following URL:
>> http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/testing/dynamic.map&map.layer[line]=DATA
>> ‘id3/vector’ END&layers=line&mode=map
>> And it is giving me this error: getString(): Symbol definition error.
>> Parsing error near (‘):(line 1)
> Quick note:
> That error usually occurs when there is a problem with the syntax of your
> CGI query string. There are notes on that at:
> http://www.mapserver.org/cgi/controls.html#changing-map-file-parameters-via-a-form-or-a-url
> My experience is that that error doesn't refer to a problem in your
> mapfile, but refers to a problem with the way you are calling mapserv.exe
> Others can hopefully assist you more thoroughly :)
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101213/12ababe0/attachment.html
