[mapserver-users] OGR data layer type - points and lines
Stephen Woodbridge woodbri at swoodbridge.com
Thu Dec 16 09:57:22 EST 2010
I do not believe that this is possible.
If you want to draw lines you have to create a data source the returns
lines not points.
The problem is that mapserver draws features and each point is a
feature. It does not have a mechanism that can read a data source and
aggregate the point features into a single line feature.
I have seen posts on the PostGIS list for SQL that can do this. You
might ask on the GDAL list if there is a way to do this. Or if you can
use PostGIS, then you can find the SQL in the archives or ask again.
-Steve W
On 12/16/2010 1:00 AM, Ian Walberg wrote:
> Hello list,
> Using an OGR connection to an sqlite data file we can get point and
> labels to draw successfully.
> However when we try and draw a line using the point data we do not get
> anything drawn.
> Layer details below.
> Thanks
> Ian
> LAYER
> NAME ogr_points
> STATUS DEFAULT
> TYPE point
> CONNECTIONTYPE OGR
> CONNECTION "points.sqlite"
> DATA "DataPoints"
> CLASS
> NAME "From OGR"
> COLOR 255 0 0
> STYLE
> SYMBOL 'City'
> SIZE 5
> COLOR 0 255 255
> END
> LABEL
> COLOR 255 255 255
> OUTLINECOLOR 0 0 0
> TYPE truetype
> FONT Unicode
> SIZE 16
> ANTIALIAS TRUE
> POSITION AUTO
> END # end of label
> END
> END
> LAYER
> NAME ogr_line
> STATUS OFF
> TYPE line
> CONNECTIONTYPE OGR
> DATA "DataPoints"
> CLASS
> STYLE
> COLOR 255 22 22
> WIDTH 2
> END
> END
> END
> mapserver-users at lists.osgeo.org
