[mapserver-users] long-running postgres queries initiated by
mapserver
Carlos Ruiz
boolean10001 at yahoo.com
Tue Dec 21 10:23:25 EST 2010
Matt,
I suggest to enhance the PostgreSQL performance at first. Each table with
geometry must have a GiST spatial
index. When you upload a shape file to PostgreSQL, the shp2pgsql creates this
index specifying the -I
parameter.
Have you uploaded your data in this way ?
If the geometry have been modified with PostGIS, you must recompute statistics
to have the index updated.
Check if you have a spatial index in your table.
Cheers from México
IC Carlos Ruiz
To: mapserver-users at lists.osgeo.org
Sent: Tue, December 21, 2010 8:48:19 AM
Subject: [mapserver-users] long-running postgres queries initiated by mapserver
Hi All-
I'm running mapserver 5.6.3 under centos 5.4, using fastcgi. I'm using
postgres as the data storage container, and mapserver is primarily serving
WFS requests. Sometimes, people do WFS queries that take a very long time
(searching for "virginia" on a nation-wide layer) and eventually postgres
will return with the result after a long time (hours later), however the
client has cancelled the WFS request. Is there any way for mapserver to
know that the client has cancelled the http request, and it can therefore
stop the DB query to postgres? I tried using persistent and non-persistent
connections with this:
PROCESSING "CLOSE_CONNECTION=DEFER"
but that didn't change the behavior.
Thanks a lot!
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/long-running-postgres-queries-initiated-by-mapserver-tp5855539p5855539.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101221/3ecbb4a6/attachment.html
