[mapserver-users] Feature points not drawn by 5.7DEV drawmap.exe
Anzel, Phil - Fort Collins, CO Phil.Anzel at ftc.usda.gov
Wed Dec 29 14:24:27 EST 2010
Happy New Year, All,
Appended below is a short map file containing two layers: points and grid lines. The projection used by the map as well as the two layers is "Web Mercator".
When drawn with "drawmap.exe" from MapServer 5.6.3, all points and grid lines are shown. Using "drawmap.exe" from 5.7-development, the points are not shown.
The 5.7-development "drawmap.exe", with associated DLLs, was downloaded from http://vbkto.dyndns.org/sdk/ on 12/15/2010. I'm using the "release-1600-gdal-mapserver.zip" file created for VS2010/Win32. The same point omission occurs if I use the "mapObj" from mapscript_csharp.dll, load the map file, and execute a "Draw" to generate an output byte array.
Is there an error in this map file? Is the difference an artifact of changes planned for 6.0, and if so, where might I find relevant documentation?
Thanks,
- Phil Anzel  (Web Soil Survey developer for USDA/NRCS)
...start of map file...
MAP
  OUTPUTFORMAT
    NAME 'pnga'
    MIMETYPE 'image/pnga'
    DRIVER 'AGG/PNG'
    EXTENSION 'png'
    IMAGEMODE 'RGBA'
    TRANSPARENT TRUE
    FORMATOPTION 'INTERLACE=OFF'
  END
  STATUS ON
  SIZE 827 511
  EXTENT -7908630.38 5546155.24 -7903127.77 5548526.51
  UNITS METERS
  IMAGECOLOR 255 255 255
  PROJECTION 'proj=merc' 'a=6378137' 'b=6378137' 'lat_ts=0.0' 'lon_0=0.0' 'x_0=0.0' 'y_0=0' 'k=1.0' 'units=m' 'nadgrids=@null' 'north' 'no_defs' END
LAYER
  layer
    name 'Corner_points'
    PROJECTION 'proj=merc' 'a=6378137' 'b=6378137' 'lat_ts=0.0' 'lon_0=0.0' 'x_0=0.0' 'y_0=0' 'k=1.0' 'units=m' 'nadgrids=@null' 'north' 'no_defs' END   # Web Mercator
    status on
    type point
    feature
      points
        -7905423.21336607 5547493.76482495
        -7905423.21336607 5546270.77237239
        -7904200.22091351 5547493.76482495
        -7904200.22091351 5546270.77237239
      end  # end of points
    end  # end of feature
    class
      style
        color 255 0 0
        size 7
      end  # end of style
    end  #end of class
  end  # end of layer
  layer
    name 'grid-WM'
    status on
    type line
    class
      color 0 0 0
    end # of class
    grid
      labelformat '%9.0f'  minarcs 2   maxarcs 6
    end  # of grid
  end # of layer 'grid-WM'
END  # end of MAP
...end of map file...
