[mapserver-users] Feature points not drawn by 5.7DEV drawmap.exe
Tamas Szekeres
szekerest at gmail.com
Wed Dec 29 19:28:56 EST 2010
Phil,
I suspect there is a problem with the default symbol initialization which
doesn't work with the new rendering code. You could work around the problem
by specifying a custom symbol as follows:
MAP
OUTPUTFORMAT
NAME 'pnga'
MIMETYPE 'image/pnga'
DRIVER 'AGG/PNG'
EXTENSION 'png'
IMAGEMODE 'RGBA'
TRANSPARENT TRUE
FORMATOPTION 'INTERLACE=OFF'
END
SYMBOL
NAME "default-marker"
TYPE ELLIPSE
POINTS
1 1
END
FILLED TRUE
END
STATUS ON
SIZE 827 511
EXTENT -7908630.38 5546155.24 -7903127.77 5548526.51
UNITS METERS
IMAGECOLOR 255 255 255
PROJECTION 'proj=merc' 'a=6378137' 'b=6378137' 'lat_ts=0.0' 'lon_0=0.0'
'x_0=0.0' 'y_0=0' 'k=1.0' 'units=m' 'nadgrids=@null' 'north' 'no_defs' END
LAYER
layer
name 'Corner_points'
# Web Mercator
status on
type point
feature
points
-7905423.21336607 5547493.76482495
-7905423.21336607 5546270.77237239
-7904200.22091351 5547493.76482495
-7904200.22091351 5546270.77237239
end # end of points
end # end of feature
class
style
color 255 0 0
size 7
SYMBOL 'default-marker'
end # end of style
end #end of class
end # end of layer
layer
name 'grid-WM'
# Web Mercator
status on
type line
class
color 0 0 0
end # of class
grid
labelformat '%9.0f' minarcs 2 maxarcs 6
end # of grid
end # of layer 'grid-WM'
END # end of MAP
A new ticket would also be sufficient in order to have this symbol
initialization problem fixed.
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101230/59f37fe8/attachment.html
