[mapserver-users] Blank image result after the call
http://localhost/mapserver/mapserv.exe?map=ecw.map&mode=map
Kiks
enrico.oemi at gmail.com
Fri Feb 19 03:59:13 EST 2010
Hi, I'm new to Mapserver, and I'm next to view my first raster image in the
browser, but I still have some problems:
My MapServer runs under IIS: I've installed the tool version (FWTools2.4.6)
and it seems to be ok.
>From the browser I try this, but the response is a blank page.
This is the content of my mapfile (ecw.map):
MAP
NAME Ortofoto
STATUS ON
SIZE 602 589
EXTENT 1546119.5 4943633.5 1552879.5 4950247.5
UNITS METERS
OUTPUTFORMAT
NAME jpeg
DRIVER "GD/JPEG"
MIMETYPE "image/jpeg"
IMAGEMODE RGB
EXTENSION "jpg"
END
CONFIG "PROJ_LIB" "C:\Programmi\FWTools2.4.6\proj_lib"
PROJECTION
"init=epsg:3003"
END
LAYER
NAME "ecw"
TYPE RASTER
STATUS ON
TRANSFORM FALSE
DATA "c:\tematismi\197120.ecw"
PROJECTION
"init=epsg:3003"
END
END # Layer
END # Map File
if I ask for capabilities
http://localhost/mapserver/mapserv.exe?map=ecw.map&SERVICE=WMS&REQUEST=GetCapabilities
the response is this:
WMS Ortofoto 2048 2048 text/xml image/jpeg image/gif image/png image/png;
mode=24bit image/vnd.wap.wbmp image/tiff image/svg+xml text/plain
application/vnd.ogc.gml text/xml image/jpeg image/gif image/png image/png;
mode=24bit image/vnd.wap.wbmp text/xml XML INIMAGE BLANK Ortofoto Ortofoto
Ortofoto EPSG:3003 9.58154 9.66746 44.6433 44.7033 ecw ecw EPSG:3003 9.58154
The problem is that I don't know how to debug and understand where I'm
wrong.
The extents of the ecw file is correct, I don't know about the projection,
but I think there is non reason to make conversion of any type.
Thanks to everyone that has any suggestion.
Kiks
View this message in context: http://n2.nabble.com/Blank-image-result-after-the-call-http-localhost-mapserver-mapserv-exe-map-ecw-map-mode-map-tp4596732p4596732.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
