[mapserver-users] changing the color of a line
Andy Colson
andy at squeakycode.net
Fri Feb 19 09:57:30 EST 2010
You can try this:
http://mapserver.org/ogc/sld.html
Like I said, I've never used it, have no idea if it'll work.
-Andy
On 2/19/2010 1:41 AM, ahmettemiz88 at gmail.com wrote:
> thank you
> Actually, I want to change color of contour map according to
> another map that lies beneath of contour map. Otherwise
> contours cannot be discerned.
> So, it' type is line.
> And I thought I might be able to change its color using
> "layer.updateFromString("COLOR 245 13 60");"
> but it failed.
> what might the alternative solutions be ?
> regards
> tarihinde, Andy Colson <andy at squeakycode.net> şunu yazdı:
> > On 2/18/2010 1:35 PM, ahmet temiz wrote:
> > hello
> > how can I change the color of a line programmatically in mapscript
> environment
> > (preferably in java)
> > regards
> > I think we need a little more info. Is this line inside a layer...
> of type LINE? Is the layer type POLYGON and you want to change one line
> of one polygon? Is the line the only thing in the layer? If there are
> lots of lines in the layer, do you know how to find the one you want?
> > As an example, which may not be helpful... I have perl mapscript that
> highlights a polygon.
> > In my mapfile I created a new, empty layer named annotate_pin, with
> coloring defined (green in my case). I do sql on my PostGIS database to
> find the polygon I want to "highlight". I copy the polygon from the
> "parcels" layer into the "annotate_pin" layer.
> > my $layer = $map->getLayerByName('parcels');
> > $layer->open();
> > #newlayer is misnamed... it does exist in the .map file
> > my $newlayer = $map->getLayerByName('annotate_pin');
> > $newlayer->{status} = $mapscript::MS_ON;
> > # sid here is set to the shape I want to copy/highlight
> > $db->pg_result();
> > ($sid) = $q->fetchrow_array;
> > # get the shape
> > my $shp = $layer->getFeature($sid);
> > $layer->close();
> > if (!$shp)
> > print STDERR "---- cannot getFeature($sid) ----\n";
> > #copy it to a new shape
> > my $shape = $shp->clone();
> > #add new shape into the annotate_pin layer
> > $newlayer->addFeature($shape);
> > ... later we draw with $map, which has one polygon in the
> annotate_pin layer.
> > Note that this is one way, there is the new styling options, but it's
> all xml and I cant stand xml, so I never even looked at it. Not sure if
> this is at all what you were looking for, but hope it helps.
> > -Andy
