[mapserver-users] Blank image result after the call
http://localhost/mapserver/mapserv.exe?map=ecw.map&mode=map
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Fri Feb 19 04:19:50 EST 2010
It is unnecessary to have EXTENT at LAYER level, but the reason for your problem is good old STATUS. Set the layer STATUS to DEFAULT and have a new try. You should see an image, and while still in good mood read the explanation from
http://www.mapserver.org/faq.html#what-does-status-mean-in-a-layer
It is also a good habit to include all the WMS parameters in the requests at least when learning and testing, in this case SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities. Mapserver does answer without VERSION and defaults to 1.1.1 then, but not all WMS servers behave that way. Same is true with CaseSensitivity, standard says that parameter values are case sensitive and while servers usually are not so strict it is better to make proper requests first and do things in a lazy and faster to type way later. You had it right, no trouble with that.
-Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Kiks
> Lähetetty: 19. helmikuuta 2010 10:59
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: [mapserver-users] Blank image result after the call
> Hi, I'm new to Mapserver, and I'm next to view my first
> raster image in the
> browser, but I still have some problems:
> My MapServer runs under IIS: I've installed the tool version
> (FWTools2.4.6)
> and it seems to be ok.
> >From the browser I try this, but the response is a blank page.
> This is the content of my mapfile (ecw.map):
> MAP
> NAME Ortofoto
> STATUS ON
> SIZE 602 589
> EXTENT 1546119.5 4943633.5 1552879.5 4950247.5
> UNITS METERS
> OUTPUTFORMAT
> NAME jpeg
> DRIVER "GD/JPEG"
> MIMETYPE "image/jpeg"
> IMAGEMODE RGB
> EXTENSION "jpg"
> END
> CONFIG "PROJ_LIB" "C:\Programmi\FWTools2.4.6\proj_lib"
> PROJECTION
> "init=epsg:3003"
> END
> LAYER
> NAME "ecw"
> TYPE RASTER
> STATUS ON
> TRANSFORM FALSE
> DATA "c:\tematismi\197120.ecw"
> PROJECTION
> "init=epsg:3003"
> END
> END # Layer
> END # Map File
> if I ask for capabilities
> http://localhost/mapserver/mapserv.exe?map=ecw.map&SERVICE=WMS
> the response is this:
> WMS Ortofoto 2048 2048 text/xml image/jpeg image/gif
> image/png image/png;
> mode=24bit image/vnd.wap.wbmp image/tiff image/svg+xml text/plain
> application/vnd.ogc.gml text/xml image/jpeg image/gif
> mode=24bit image/vnd.wap.wbmp text/xml XML INIMAGE BLANK
> Ortofoto Ortofoto
> Ortofoto EPSG:3003 9.58154 9.66746 44.6433 44.7033 ecw ecw
> EPSG:3003 9.58154
> The problem is that I don't know how to debug and understand where I'm
> wrong.
> The extents of the ecw file is correct, I don't know about
> the projection,
> but I think there is non reason to make conversion of any type.
> Thanks to everyone that has any suggestion.
> Kiks
> http://n2.nabble.com/Blank-image-result-after-the-call-http-lo
> calhost-mapserver-mapserv-exe-map-ecw-map-mode-map-tp4596732p4
> 596732.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
