[mapserver-users] Re: Blank image result after the call
http://localhost/mapserver/mapserv.exe?map=ecw.map&mode=map
Kiks
enrico.oemi at gmail.com
Fri Feb 19 10:55:52 EST 2010
I resolved the problem.
I was using FWtools2.4.6 (MapServer 5.6.0 Beta4), that hadn't enabled the
AGG Rendering driver.
I tried to switch to MS4W 5.2.1, and change the OUTPUTFORMAT in mapfile to
this:
OUTPUTFORMAT
NAME 'AGG'
DRIVER AGG/PNG
IMAGEMODE RGB
END
Now it works fine.
Kiks
View this message in context: http://n2.nabble.com/Blank-image-result-after-the-call-http-localhost-mapserver-mapserv-exe-map-ecw-map-mode-map-tp4596732p4598561.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
