[mapserver-users] Server Root
Andrew Lewin alewin at spatialconserve.com
Fri Feb 19 19:52:43 EST 2010
Dear Listers,
I am a beginner user of Mapserver.  I installed Mapserver and Apache2
successfully.  I am running Mac OS X 10.5.8 Leopard.
I downloaded the tutorial data and tried to view Example 1, but I was
unable to do so.  I got the error for the following command:
http://192.168.1.147/cgi-bin/mapserv?map=/ms4w/apps/tutorial/htdocs/example1-1.map&layer=states&mode=map
msLoadMap(): Unable to access file. (/ms4w/apps/tutorial/htdocs/
example1-1.map)
  I noticed that the example1-1.map was not in the htdocs file in the
file tree that I downloaded, but it was in the mapfile folder.
I still got the same error.
I searched around for the solutions on the web, but I didn't really
understand them.  I think the problem is that I can't find the web
root where the files should be stored.
I looked in the httpd.config file and saw that the ServerRoot was "/
usr" so I added the tutorial files in that folder, but again no
solution.  What am I doing wrong?
I would appreciate any help you can provide?
Thanks,
Andrew
Andrew Lewin, M.Sc., Adv. Dipl. GIS
President
Spatial-Conserve Inc.
www.spatialconserve.com
Email: alewin at spatialconserve.com
Tel: (905) 639-4646
Mobile: (905) 630-8441
Skype: andrew.lewin99
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100219/819f698a/attachment.html
