Re: [mapserver-users] How to add HDF-EOS data layer in MapServer
Ivan Lucena ivan.lucena at pmldnet.com
Fri Feb 26 11:21:11 EST 2010
Hi Venkat,
If gdalinfo is not showing the subdataset list, like in you case, it would be impossible to identify a dataset as your DATA parameter.
What version is the GDAL that you are using on command line? Is that the same that mapserver is using?
Note that there are some flavors of HDF products that are not supported by all version of GDAL/HDF.
Regards,
Ivan
>  -------Original Message-------
>  From: Venkat Shesu Reddem <venkat.shesu at gmail.com>
>  To: mapserver-users at lists.osgeo.org
>  Subject: [mapserver-users] How to add HDF-EOS data layer in MapServer
>  Sent: Feb 26 '10 11:02
>  Dear All,
>  I am trying to add HDF-EOS data layer to MapServer application. Can anyone
>  help me in defining the syntax of the layer.
>  the following is the "gdalinfo" for the given HDF dataset
>  Driver: HDF5Image/HDF5 Dataset
>  Files: none associated
>  Size is 1440, 720
>  Coordinate System is:
>  GEOGCS["WGS 84",
>     DATUM["WGS_1984",
>         SPHEROID["WGS 84",6378137,298.257223563,
>             AUTHORITY["EPSG","7030"]],
>         TOWGS84[0,0,0,0,0,0,0],
>         AUTHORITY["EPSG","6326"]],
>     PRIMEM["Greenwich",0,
>         AUTHORITY["EPSG","8901"]],
>     UNIT["degree",0.0174532925199433,
>         AUTHORITY["EPSG","9108"]],
>     AUTHORITY["EPSG","4326"]]
>  Metadata:
>  FILE_ATTRIBUTES:OrbitNumber=29703 29704 29705 29706 29707 29708 29709
>  29710 29711 29712 29713 29714 29715 29716 29717 29718 29719 29720 29721
>  29722 29723 29724 29725 29726 29727 29728 29729 29730 29731 29732 29733
>  29734 29735 29736 29737 29738 29739 29740 29741 29742 29743 29744 29745
>  29746 29747
>  FILE_ATTRIBUTES:OrbitPeriod=5933 5934 5933 5934 5933 5934 5933 5934 5933
>  5934 5933 5933 5934 5933 5934 5933 5934 5933 5934 5933 5934 5933 5934 5933
>  5934 5933 5934 5933 5934 5933 5934 5933 5933 5934 5934 5933 5934 5933 5933
>  FILE_ATTRIBUTES:InstrumentName=OMI
>  FILE_ATTRIBUTES:ProcessLevel=3e
>  FILE_ATTRIBUTES:GranuleMonth=2
>  FILE_ATTRIBUTES:GranuleDay=15
>  FILE_ATTRIBUTES:GranuleYear=2010
>  FILE_ATTRIBUTES:GranuleDayOfYear=46
>  FILE_ATTRIBUTES:TAI93At0zOfGranule=5.40346e+008
>  FILE_ATTRIBUTES:PGEVersion="1.0.5.1"
>  FILE_ATTRIBUTES:StartUTC=2010-02-14T12:15:00.000000Z
>  FILE_ATTRIBUTES:EndUTC=2010-02-16T11:45:00.000000Z
>  FILE_ATTRIBUTES:Period=Daily
>  OMI Column Amount O3:GCTPProjectionCode=0
>  OMI Column Amount O3:Projection=Geographic
>  OMI Column Amount O3:GridOrigin=Center
>  OMI Column Amount O3:GridSpacing=(0.25,0.25)
>  OMI Column Amount O3:GridSpacingUnit=deg
>  OMI Column Amount O3:GridSpan=(-180,180,-90,90)
>  OMI Column Amount O3:GridSpanUnit=deg
>  OMI Column Amount O3:NumberOfLongitudesInGrid=1440
>  OMI Column Amount O3:NumberOfLatitudesInGrid=720
>  HDFEOS INFORMATION:HDFEOSVersion=HDFEOS_5.1.11
>  Corner Coordinates:
>  Upper Left  (    0.0,    0.0)
>  Lower Left  (    0.0,  720.0)
>  Upper Right ( 1440.0,    0.0)
>  Lower Right ( 1440.0,  720.0)
>  Center      (  720.0,  360.0)
>  Band 1 Block=1440x1 Type=Float32, ColorInterp=Undefined
>  Metadata:
>  RadiativeCloudFraction:_FillValue=-1267650600228229400000000000000.000000
>     RadiativeCloudFraction:Units=NoUnits
>     RadiativeCloudFraction:Title=Radiative Cloud Fraction = fc*Ic331/Im331
>     RadiativeCloudFraction:UniqueFieldDefinition=TOMS-OMI-Shared
>     RadiativeCloudFraction:ScaleFactor=1
>     RadiativeCloudFraction:Offset=0
>     RadiativeCloudFraction:ValidRange=0.000000 1.000000
>  RadiativeCloudFraction:MissingValue=-1267650600228229400000000000000.000000
>  with thanks & regards
>  Venkat
>  _______________________________________________
>  mapserver-users mailing list
>  http://lists.osgeo.org/mailman/listinfo/mapserver-users
