[mapserver-users] How to add HDF-EOS data layer in MapServer
Venkat Shesu Reddem
venkat.shesu at gmail.com
Sun Feb 28 22:49:29 EST 2010
Hi Ivan,
gdalinfo is showing subdataset list also, the previous mail contains
gdalinfo of one of subdataset. I have used gdal_translate to convert
the following in GeoTIFF image, however i don't have idea about how to
create layer for the given hdf subdataset.
the below is the gdalinfo showing subdataset list:
Driver: HDF5Image/HDF5 Dataset
Files: none associated
Size is 1440, 720
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9108"]],
AUTHORITY["EPSG","4326"]]
Metadata:
FILE_ATTRIBUTES:OrbitNumber=29703 29704 29705 29706 29707 29708
29709 29710 29711 29712 29713 29714 29715 29716 29717 29718 29719
29720 29721 29722 29723 29724 29725 29726 29727 29728 29729 29730
29731 29732 29733 29734 29735 29736 29737 29738 29739 29740 29741
29742 29743 29744 29745 29746 29747
FILE_ATTRIBUTES:OrbitPeriod=5933 5934 5933 5934 5933 5934 5933 5934
5933 5934 5933 5933 5934 5933 5934 5933 5934 5933 5934 5933 5934 5933
5934 5933 5934 5933 5934 5933 5934 5933 5934 5933 5933 5934 5934 5933
FILE_ATTRIBUTES:InstrumentName=OMI
FILE_ATTRIBUTES:ProcessLevel=3e
FILE_ATTRIBUTES:GranuleMonth=2
FILE_ATTRIBUTES:GranuleDay=15
FILE_ATTRIBUTES:GranuleYear=2010
FILE_ATTRIBUTES:GranuleDayOfYear=46
FILE_ATTRIBUTES:TAI93At0zOfGranule=5.40346e+008
FILE_ATTRIBUTES:PGEVersion="1.0.5.1"
FILE_ATTRIBUTES:StartUTC=2010-02-14T12:15:00.000000Z
FILE_ATTRIBUTES:EndUTC=2010-02-16T11:45:00.000000Z
FILE_ATTRIBUTES:Period=Daily
OMI Column Amount O3:GCTPProjectionCode=0
OMI Column Amount O3:Projection=Geographic
OMI Column Amount O3:GridOrigin=Center
OMI Column Amount O3:GridSpacing=(0.25,0.25)
OMI Column Amount O3:GridSpacingUnit=deg
OMI Column Amount O3:GridSpan=(-180,180,-90,90)
OMI Column Amount O3:GridSpanUnit=deg
OMI Column Amount O3:NumberOfLongitudesInGrid=1440
OMI Column Amount O3:NumberOfLatitudesInGrid=720
HDFEOS INFORMATION:HDFEOSVersion=HDFEOS_5.1.11
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 720.0)
Upper Right ( 1440.0, 0.0)
Lower Right ( 1440.0, 720.0)
Center ( 720.0, 360.0)
Band 1 Block=1440x1 Type=Float32, ColorInterp=Undefined
Metadata:
RadiativeCloudFraction:_FillValue=-1267650600228229400000000000000.000000
RadiativeCloudFraction:Units=NoUnits
RadiativeCloudFraction:Title=Radiative Cloud Fraction = fc*Ic331/Im331
RadiativeCloudFraction:UniqueFieldDefinition=TOMS-OMI-Shared
RadiativeCloudFraction:ScaleFactor=1
RadiativeCloudFraction:Offset=0
RadiativeCloudFraction:ValidRange=0.000000 1.000000
RadiativeCloudFraction:MissingValue=-1267650600228229400000000000000.000000
Driver: HDF5/Hierarchical Data Format Release 5
Files: OMI.he5
Size is 512, 512
Coordinate System is `'
Metadata:
Subdatasets:
SUBDATASET_0_NAME=HDF5:"OMI.he5"://HDFEOS/GRIDS/OMI_Column_Amount_O3/Data_Fields/ColumnAmountO3
SUBDATASET_0_DESC=[720x1440]
//HDFEOS/GRIDS/OMI_Column_Amount_O3/Data_Fields/ColumnAmountO3 (32-bit
floating-point)
SUBDATASET_1_NAME=HDF5:"OMI.he5"://HDFEOS/GRIDS/OMI_Column_Amount_O3/Data_Fields/RadiativeCloudFraction
SUBDATASET_1_DESC=[720x1440]
(32-bit floating-point)
SUBDATASET_2_NAME=HDF5:"OMI.he5"://HDFEOS/GRIDS/OMI_Column_Amount_O3/Data_Fields/SolarZenithAngle
SUBDATASET_2_DESC=[720x1440]
SUBDATASET_3_NAME=HDF5:"OMI.he5"://HDFEOS/GRIDS/OMI_Column_Amount_O3/Data_Fields/ViewingZenithAngle
SUBDATASET_3_DESC=[720x1440]
Corner Coordinates:
Lower Left ( 0.0, 512.0)
Upper Right ( 512.0, 0.0)
Lower Right ( 512.0, 512.0)
Center ( 256.0, 256.0)
with thanks & regards
Venkat
On Fri, Feb 26, 2010 at 4:21 PM, Ivan Lucena <ivan.lucena at pmldnet.com> wrote:
> Hi Venkat,
> If gdalinfo is not showing the subdataset list, like in you case, it would be impossible to identify a dataset as your DATA parameter.
> What version is the GDAL that you are using on command line? Is that the same that mapserver is using?
> Note that there are some flavors of HDF products that are not supported by all version of GDAL/HDF.
> Regards,
> Ivan
>> -------Original Message-------
>> From: Venkat Shesu Reddem <venkat.shesu at gmail.com>
>> To: mapserver-users at lists.osgeo.org
>> Subject: [mapserver-users] How to add HDF-EOS data layer in MapServer
>> Sent: Feb 26 '10 11:02
>> Dear All,
>> I am trying to add HDF-EOS data layer to MapServer application. Can anyone
>> help me in defining the syntax of the layer.
>> the following is the "gdalinfo" for the given HDF dataset
>> Size is 1440, 720
>> GEOGCS["WGS 84",
>> DATUM["WGS_1984",
>> Metadata:
>> FILE_ATTRIBUTES:OrbitNumber=29703 29704 29705 29706 29707 29708 29709
>> 29710 29711 29712 29713 29714 29715 29716 29717 29718 29719 29720 29721
>> 29722 29723 29724 29725 29726 29727 29728 29729 29730 29731 29732 29733
>> 29734 29735 29736 29737 29738 29739 29740 29741 29742 29743 29744 29745
>> 29746 29747
>> FILE_ATTRIBUTES:OrbitPeriod=5933 5934 5933 5934 5933 5934 5933 5934 5933
>> 5934 5933 5933 5934 5933 5934 5933 5934 5933 5934 5933 5934 5933 5934 5933
>> 5934 5933 5934 5933 5934 5933 5934 5933 5933 5934 5934 5933 5934 5933 5933
>> Corner Coordinates:
>> Metadata:
>> Venkat
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
