[mapserver-users] MAPSCRIPT - queryByAttributes on WFS layer
Charlotte DECLERCQ c.declercq at alkante.com
Wed Jan 6 03:07:43 EST 2010
Hello Daniel and thanks for the quick answer.
$oLayer->queryByAttributes($m_Champs, "(".stripslashes($m_Requete).")",
MS_MULTIPLE );
doesn't seem to work with $m_Requete : upper(gid) = upper(\'140\').
Is it possible to do some comparison like gid > 140 ... on a WFS layer?
I know it is possible on other types of layers.
Charlotte DECLERCQ
ALKANTE SAS
Ingénieur R&D SIG
1, rue du Chêne Morand
35 510 Cesson-Sévigné
Bur: + 33 (0) 2 99 22 25 70
fax : + 33 (0) 2 99 32 12 76
----- Mail Original -----
De: "Daniel Morissette" <dmorissette at mapgears.com>
À: mapserver-users at lists.osgeo.org
Envoyé: Mardi 5 Janvier 2010 17:10:28
Objet: Re: [mapserver-users] MAPSCRIPT - queryByAttributes on WFS layer
Charlotte DECLERCQ wrote:
> Hello,
> I am trying to launch a query on a WFS layer.
> The query is :
> $oLayer->queryByAttributes($m_Champs, "\"".stripslashes($m_Requete)."\"", MS_MULTIPLE );
> with $m_Champs : gid
> Whereas there is one record matching, mapserver can't find it : No matching record(s) found.
> I obtain the same result with $m_Requete : gid = '140', or gid = 140, or gid = \'140\'
> But if $m_Requete is equals to 140, then mapserver returns the element.
> Any idea?
> Thanks,
If $m_Requete contains a logical expression such as "gid = '140'" then
you need to enclose it inside round brackets for the parser to detect
that it is a logical expression. If you enclose it inside double quotes
(as you did above) then it treats $m_requete as a constant that is
matched against $m_champs. That's why things work when you use
$m_requete = "140";
So the best fix is to use $m_requete = "140" with the
queryByAttributes() statement above since constant expressions are the
fastest.
However, if you want to pass a logical expression for some reason, then
you should use:
MS_MULTIPLE );
Daniel
Daniel Morissette
http://www.mapgears.com/
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
