[mapserver-users] New Mapserver install
Andy Colson
andy at squeakycode.net
Sun Jan 10 22:59:13 EST 2010
On 01/10/2010 09:39 PM, bascom49 wrote:
> Andy Colson wrote:
>> On 01/10/2010 08:55 PM, bascom49 wrote:
>>> Andy Colson wrote:
>>>> On 01/10/2010 04:11 PM, bascom49 wrote:
>>>>> Ive installed mapserver on a vps server under centos 5 linux. I'm
>>>>> having
>>>>> problems with setting up mapscript.
>>>>> My php setup is :
>>>>> http://174.120.238.19/info.php
>>>>> The output from mapserv -v is:
>>>>> root at inf [/usr/local/apache/cgi-bin]# /usr/local/apache/cgi-bin/mapserv
>>>>> -v
>>>>> MapServer version 5.4.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>>>>> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=ICONV
>>>>> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_CLIENT
>>>>> SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=THREADS SUPPORTS=GEOS
>>>>> INPUT=TIFF INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
>>>>> INPUT=SHAPEFILE
>>>>> php_mapscript.so is located at:
>>>>> /usr/local/lib/php/extensions/no-debug-non-zts-20060613/php_mapscript.so
>>>>> I compiled mapserver 5.4.2 from source.
>>>>> Can someone please help me trouble shoot my install ?
>>>> I don't see a problem, or an error. So what do you need help with?
>>>> -Andy
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>> I expected to see a mapscript entry in the output from phpinfo(0),
>>> similar
>>> to
>>> what is shown here :
>>> http://www.londatiga.net/it/installing-mapserver-and-php-mapscript-on-linux/
>>> Any insight that you may have is greatly appreciated.
>>> Thanks,
>>> Charles
>> Ah, did you add an entry into the php.ini (in the extensions group)?
>> -Andy
> I added :
> extension = “php_mapscript.so” to php.ini.
> I did not add a new path entry as I had copied php_mapscript.so to the
> default php extensions directory
> that I saw listed from the output of phpinfo().
> Is there something that I need to do to force php.ini to be reloaded ?
Yeah, you have to restart apache.
