[mapserver-users] cofigure problems on Ubuntu 9.10
Vasile Cristian Stan
vasileestan at gmail.com
Mon Jan 11 05:24:41 EST 2010
In the conf.log i have this output for jpeg
"configure:11147: checking checking ms JPEG output
configure:11151: result: no we, have GDAL available."
after all I made installation of binaries packages from /launchpad.net
Thanks Alan for the reply and for the easy way (launchpad packages)
#Vasi :handshake:
Alan Boudreault wrote:
> I'm mostly sure that the configure script is right, because we use it on
> Ubuntu Karmic.
> You can see the the configure options used to build the package on karmic
> there:
> http://svn.debian.org/wsvn/pkg-
> grass/packages/mapserver/tags/5.6.0%2Bfinal-1/debian/rules
> I don't see "--with-png" in your config options... you should add it if
> you
> want the support.
> Otherwise, I suggest to take a look at the "config.log" file to see what's
> happen in detail.
> Hope this help.
> Alan
> On January 7, 2010 07:42:29 am Vasile Cristian Stan wrote:
>> Thanks Alan
>> The packages are installed.
>> ii libjpeg62-dev 6b-14build1 Development files for the IJG JPEG
>> library
>> ii libpng12-dev 1.2.37-1 PNG library - development
>> Also, I tried to configure using another script presented here:
>> http://n2.nabble.com/Error-running-configure-on-a-Linux-machine-td3278036.h
>> tml#a3278036 , and with this script jpeg and png works but the rest of
>> packages are not included.
>> So, there are no problems with the packages, maybe the configuration
>> script
>> is wrong.
>> # Vasi
>> > I would suggest to verify with the dpkg command line if the packages
>> > |libpng12-dev and ||libjpeg62-dev |are installed.
>> > You can also take a look to these binarie packages:
>> > https://launchpad.net/~ubuntugis/+archive/ubuntugis-unstable , which
>> > contain mapserver 5.6.0.
>> > Alan
>> > luftadler wrote:
>> >> Hi everyone,
>> >> I try to install MapServer 5.6.0, for the first time, on my machine
>> >> (using
>> >> Ubuntu 9.10).
>> >> The problem is that my configuration don't find few installed
>> libraries
>> >> like: png and jpeg.
>> >> My configuration script:
>> >> ./configure \
>> >> --enable-debug \
>> >> --prefix=/usr \
>> >> --with-xml2 \
>> >> --with-pdf \
>> >> --with-gd \
>> >> --with-jpeg \
>> >> --with-freetype \
>> >> --with-agg \
>> >> --with-eppl \
>> >> --with-proj \
>> >> --with-threads \
>> >> --with-sde \
>> >> --with-geos \
>> >> --with-ogr \
>> >> --with-gdal \
>> >> --with-tiff \
>> >> --with-postgis \
>> >> --with-wfs \
>> >> --with-wcs \
>> >> --with-wmsclient \
>> >> --with-wfsclient \
>> >> --with-sos \
>> >> --with-fribidi-config \
>> >> --with-php=/usr/include/php5 \
>> >> --with-httpd=/usr/sbin/apache2 \
>> >> ______________________________________________
>> >> MapServer is now configured for
>> >> -------------- Compiler Info -------------
>> >> C compiler: gcc -g -fPIC -Wall
>> >> C++ compiler: g++ -g -fPIC -Wall
>> >> Debug: -g
>> >> Generic NINT:
>> >> -------------- Renderer Settings ---------
>> >> OpenGL support:
>> >> zlib support: -DUSE_ZLIB
>> >> png support:
>> >> palette rgba png support:
>> >> jpeg support:
>> >> iconv support: -DUSE_ICONV
>> >> AGG support: -DUSE_AGG
>> >> Cairo (SVG,PDF) support:
>> >> Ming(flash) support:
>> >> PDFLib support: -DUSE_PDF
>> >> -------------- Support Libraries ---------
>> >> Proj.4 support: -DUSE_PROJ
>> >> Libxml2 support: -DUSE_LIBXML2
>> >> FriBidi support: -DUSE_FRIBIDI
>> >> Curl support: -DUSE_CURL
>> >> FastCGI support:
>> >> Threading support: -DUSE_THREAD
>> >> GEOS support: -DUSE_GEOS -DGEOS_HAS_SIMPLIFY
>> >> -------------- Data Format Drivers -------
>> >> native tiff support: -DUSE_TIFF
>> >> PostGIS support: -DUSE_POSTGIS
>> >> EPPL7 support: -DUSE_EPPL
>> >> ArcSDE support:
>> >> OGR support: -DUSE_OGR
>> >> GDAL support: -DUSE_GDAL
>> >> Oracle Spatial support:
>> >> -------------- OGC Services --------------
>> >> WMS Server: -DUSE_WMS_SVR
>> >> WMS Client: -DUSE_WMS_LYR
>> >> WFS Server: -DUSE_WFS_SVR
>> >> WFS Client: -DUSE_WMS_LYR
>> >> WCS Server: -DUSE_WCS_SVR
>> >> SOS Server: -DUSE_SOS_SVR
>> >> -------------- MapScript -----------------
>> >> PHP MapScript: yes
>> >> #Vasi
> Alan Boudreault
> Mapgears
> http://www.mapgears.com
> mapserver-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/cofigure-problems-on-Ubuntu-9-10-tp4260091p4284719.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
