[mapserver-users] symbol circle (ellipse) rendered not round
but oval
Fawcett, David (MPCA)
David.Fawcett at state.mn.us
Tue Jan 12 10:33:57 EST 2010
Are you requesting your image through a WMS and maybe getting a ‘non-square pixel’ effect?
If you are using WMS, are the symbols round when you do a cgi request in mode=map or mode=tile?
David.
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Oliver Christen
Sent: Tuesday, January 12, 2010 9:31 AM
To: thomas bonfort
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] symbol circle (ellipse) rendered not round but oval
Hi Thomas :)
thanks for the answer, but sadely it didnt solve my problem:
here are a few tests I did:
using GAP 20 gave me really weird result:
http://dev.camptocamp.com/~ochriste/tilecache6_gap_20.png
using PATTERN 1 22 END gave me better result, but the dot are still slightly oval:
http://dev.camptocamp.com/~ochriste/tilecache7_pattern.png
I wondered if the visual effect may have come from the fact im pilling up two circle one over the other, but even when trying to display only the outer or inner circles, the circle are still slightly off:
http://dev.camptocamp.com/~ochriste/tilecache4_outercircle.png
http://dev.camptocamp.com/~ochriste/tilecache5_innercircle.png
(both at once http://dev.camptocamp.com/~ochriste/tilecache3_bothcircle.png)
any other idea? ^_^
----- Original Message -----
From: thomas bonfort<mailto:thomas.bonfort at gmail.com>
To: Oliver Christen<mailto:oliver.christen at camptocamp.com>
Cc: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Sent: Tuesday, January 12, 2010 3:18 PM
hi Oliver :)
try with GAP 20 instead of STYLE 1 20 END (which is deprecated btw, use PATTERN now)
cheers,
thomas
On Tue, Jan 12, 2010 at 15:04, Oliver Christen <oliver.christen at camptocamp.com<mailto:oliver.christen at camptocamp.com>> wrote:
hello
I have a weird problem with symbology.
Im rendering a line with dots, but the dots are not round but slightly oval, see image http://dev.camptocamp.com/~ochriste/tilecache.png
Any idea what could be the cause ?
Here is my symbol definition:
SYMBOL
NAME "linie-gepunkt10"
TYPE ELLIPSE
POINTS
1 1
END
STYLE
1 20
END
FILLED TRUE
END
and my layer's class definition:
CLASS
EXPRESSION "3"
MAXSCALEDENOM 200001
STYLE
SYMBOL "linie-gepunkt10"
SIZE 10
COLOR 102 51 0
END
STYLE
SIZE 8
COLOR 204 102 0
END
END
and the map outputformat:
OUTPUTFORMAT
NAME png
DRIVER "AGG/PNG"
MIMETYPE "image/png"
IMAGEMODE RGBA
EXTENSION "png"
FORMATOPTION "INTERLACE=OFF"
END
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100112/6347b0c8/attachment-0001.html
