[mapserver-users] symbol circle (ellipse) rendered not round but
oval
thomas bonfort
thomas.bonfort at gmail.com
Tue Jan 12 10:56:02 EST 2010
gap in pixels = symbol->gap * style->size
On Tue, Jan 12, 2010 at 16:52, Oliver Christen <
oliver.christen at camptocamp.com> wrote:
> GAP 20 is really giving unwanted result:
> http://dev.camptocamp.com/~ochriste/tilecache9.png<http://dev.camptocamp.com/%7Eochriste/tilecache9.png>
> though using only one style instead of two seems to solve the oval problem
> (but why ???)
> style
> symbol "dots"
> size 8
> color 204 102 0
> outlinecolor 102 51 0
> end
> I dont understand how GAP is supposed working:
> with GAP 2, I had ~10px between dots,
> with GAP 3, I had ~18px between dots,
> with GAP 4, I had ~26px between dots
> whats the logic ?
> ----- Original Message -----
> *From:* thomas bonfort <thomas.bonfort at gmail.com>
> *To:* Oliver Christen <oliver.christen at camptocamp.com>
> *Cc:* mapserver-users at lists.osgeo.org
> *Sent:* Tuesday, January 12, 2010 4:36 PM
> *Subject:* Re: [mapserver-users] symbol circle (ellipse) rendered not
> round but oval
> symbol
> name dots
> type ellipse
> points 1 1 end
> gap 20
> end
> style
> symbol "dots"
> size 8
> color r g b
> outlinecolor r g b
> end
> On Tue, Jan 12, 2010 at 16:31, Oliver Christen <
>> Hi Thomas :)
>> thanks for the answer, but sadely it didnt solve my problem:
>> here are a few tests I did:
>> using GAP 20 gave me really weird result:
>> http://dev.camptocamp.com/~ochriste/tilecache6_gap_20.png<http://dev.camptocamp.com/%7Eochriste/tilecache6_gap_20.png>
>> using PATTERN 1 22 END gave me better result, but the dot are still
>> slightly oval:
>> http://dev.camptocamp.com/~ochriste/tilecache7_pattern.png<http://dev.camptocamp.com/%7Eochriste/tilecache7_pattern.png>
>> I wondered if the visual effect may have come from the fact im pilling up
>> two circle one over the other, but even when trying to display only the
>> outer or inner circles, the circle are still slightly off:
>> http://dev.camptocamp.com/~ochriste/tilecache4_outercircle.png<http://dev.camptocamp.com/%7Eochriste/tilecache4_outercircle.png>
>> http://dev.camptocamp.com/~ochriste/tilecache5_innercircle.png<http://dev.camptocamp.com/%7Eochriste/tilecache5_innercircle.png>
>> (both at once
>> http://dev.camptocamp.com/~ochriste/tilecache3_bothcircle.png<http://dev.camptocamp.com/%7Eochriste/tilecache3_bothcircle.png>
>> any other idea? ^_^
>> *Sent:* Tuesday, January 12, 2010 3:18 PM
>> round but oval
>> hi Oliver :)
>> try with GAP 20 instead of STYLE 1 20 END (which is deprecated btw, use
>> PATTERN now)
>> cheers,
>> thomas
>> On Tue, Jan 12, 2010 at 15:04, Oliver Christen <
>>> hello
>>> I have a weird problem with symbology.
>>> Im rendering a line with dots, but the dots are not round but slightly
>>> oval, see image http://dev.camptocamp.com/~ochriste/tilecache.png<http://dev.camptocamp.com/%7Eochriste/tilecache.png>
>>> Any idea what could be the cause ?
>>> Here is my symbol definition:
>>> SYMBOL
>>> NAME "linie-gepunkt10"
>>> TYPE ELLIPSE
>>> POINTS
>>> 1 1
>>> END
>>> STYLE
>>> 1 20
>>> END
>>> FILLED TRUE
>>> END
>>> and my layer's class definition:
>>> CLASS
>>> EXPRESSION "3"
>>> MAXSCALEDENOM 200001
>>> STYLE
>>> SYMBOL "linie-gepunkt10"
>>> SIZE 10
>>> COLOR 102 51 0
>>> END
>>> STYLE
>>> SIZE 8
>>> COLOR 204 102 0
>>> END
>>> END
>>> and the map outputformat:
>>> OUTPUTFORMAT
>>> NAME png
>>> DRIVER "AGG/PNG"
>>> MIMETYPE "image/png"
>>> IMAGEMODE RGBA
>>> EXTENSION "png"
>>> FORMATOPTION "INTERLACE=OFF"
>>> END
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100112/e7a4850e/attachment-0001.html
