[mapserver-users] VRT / CSV data sources are not displayed in
a layer
Stefan Schantz
SSchantz at BfS.de
Fri Jan 22 02:55:09 EST 2010
Hello Frank, hello Carlos
my CSV-file and my VRT-file looks like this:
> My CSV is
> x-utm,y-utm,Wert
> 742226., 5374978., 0.00E+00
> 743422., 5375072., 0.00E+00
> 744620., 5375166., 0.00E+00
> and my VTR is
> <OGRVRTDataSource>
> <OGRVRTLayer name="boden">
> <SrcDataSource>/daten/csv/boden.csv</SrcDataSource>
> <GeometryType>wkbPoint</GeometryType>
> <GeometryField encoding="PointFromColumns" x="x-utm" y="y-utm"/>
> </OGRVRTLayer>
> </OGRVRTDataSource>
As you can see, I use absolute paths for the datasource. I also tried to
use a wrong relative path and in this case I got an error from the
Mapserver, so I think the mapserver can find the csv-file with the
absolute path .
Even if I add the source layer tag <SrcLayer>boden</SrcLayer> as Carlos
told before , the result is negative and I get a blank picture from
the Mapserver.
Any other idea?
Thanks
Stefan
Frank Warmerdam schrieb:
> Stefan,
> I would suspect that your .vrt file contains relative rather
> than absolute paths and that they are relative to a
> different working directory if used from MapServer.
> There is an attribute for the <SrcDataSource> that
> may address this. It might help if you posted the
> VRT.
> 2010/1/20 Stefan Schantz <SSchantz at bfs.de>:
>> Hello List,
>> The following layer uses a CSV-file (together with a VRT-File (Virtual
>> Format) ) as datasource . When I try to visualize the layer, nothing is
>> shown (neither the data nor error messages; shp2img shows also nothing)
>> LAYER
>> NAME "boden"
>> DEBUG on
>> STATUS ON
>> TYPE POINT
>> # DATA "/daten/csv/boden/boden" # Datenquelle Shapefile
>> CONNECTION "/daten/csv/boden.vrt"
>> CONNECTIONTYPE OGR
>> PROJECTION
>> "init=epsg:25832"
>> END
>> METADATA
>> "WMS_TITLE" "test"
>> "WMS_SRS" "EPSG:25832"
>> "WMS_ABSTRACT" "test"
>> "WMS_FEATURE_INFO_MIME_TYPE" 'text/html'
>> END
>> CLASS
>> NAME "test"
>> STYLE
>> SYMBOL "circle"
>> SIZE 15 COLOR 90 90 90
>> END
>> END END
>> But if I transform the CSV/VRT-file into a Shapefile via ogr2ogr
>> ogr2ogr -s_srs EPSG:25832 -t_srs EPSG:25832 -f "ESRI Shapefile" boden
>> boden.vrt
>> the layer displays the data.
>> What is wrong with my VRT/CSV-datasource in the mapfile?
>> Thanks for any idea.
>> Best regards
>> Stefan
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
<OGRVRTDataSource>
<LayerSRS>EPSG:25832</LayerSRS>
</OGRVRTLayer>
</OGRVRTDataSource>
Type: application/vnd.ms-excel
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100122/165d9d5f/boden-0001.xlb
