[mapserver-users] resolution
Valeria Muñoz
valemunoz at gmail.com
Mon Jan 25 13:24:18 EST 2010
ok, i update mapserver version to 5.6, i change my mapfile, but I still in
72 dpi...
mapfile
MAP
NAME neonline_mapa
RESOLUTION 300
DEFRESOLUTION 72
SIZE 1667 1667
UNITS dd
SHAPEPATH "c:/ms4w/Apache/htdocs/test_mapfile/data2/"
EXTENT -112.888238 -57.06133625 -7.419488000000001 13.25116375
FONTSET "c:/ms4w/Apache/htdocs/test_map_dis/fonts/fonts.txt"
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
# Background color for the map canvas -- change as desired
IMAGECOLOR 122 206 232
IMAGETYPE pdf
OUTPUTFORMAT
NAME png
DRIVER "AGG/PNG"
MIMETYPE 'image/png'
IMAGEMODE RGB
EXTENSION "png"
FORMATOPTION "TRANSPARENT=ON"
FORMATOPTION "INTERLACE=ON"
FORMATOPTION "QUANTIZE_COLORS=256"
END
# Legend
LEGEND
IMAGECOLOR 255 255 255
STATUS ON
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
END
2010/1/25 Jeff McKenna <jmckenna at gatewaygeomatics.com>
> Alan Boudreault wrote:
>> Sorry, I was sure you was trying to use the new feature included in
>> MapServer 5.6. In MS <5.6, you can't really do more that setting the
>> resolution to 300.
> If you are using MS4W 3.0, you can extract the "MapServer version 5.6.0
> release Upgrade" package on the MS4W downloads page [1], to install
> MapServer 5.6.0
> If you have questions about performing this upgrade, please use the MS4W
> email list[2].
> [1] http://www.maptools.org/ms4w/index.phtml?page=downloads.html
> [2] http://lists.maptools.org/mailman/listinfo/ms4w-users
> -jeff
> Jeff McKenna
> FOSS4G Consulting and Training Services
> http://www.gatewaygeomatics.com/
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100125/fe626f96/attachment.html
