[mapserver-users] C# query method
Murty Maganti
MMaganti at oriongis.com
Fri Jan 29 14:51:13 EST 2010
Hi Steve/Tamas
Until now I was under the impression that I can't do a query by
attributes and shape in a single call. Hence I had written my code
first to execute query by shape and append those results to query
expression as IN clause and invoke queryByAttributes.
While doing some testing on oracle spatial layer, I found that
queryByShape is actually honoring filter expression on the layer. Since
this will be executed as a single call, I want to modify my code to call
only queryByShape and set the query expression to filter. This will
improve overall time taken for the query execution but I want to make
sure that his behavior is consistent across all data sets (providers).
Thanks
Murty
From: Lime, Steve D (DNR) [mailto:Steve.Lime at state.mn.us]
Sent: Friday, January 29, 2010 2:27 PM
To: Tamas Szekeres; Murty Maganti
Cc: mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] C# query method
The one notable exception is the queryByAttribute method. It definitely
ignores the existing filter.
Steve
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Tamas
Szekeres
Sent: Friday, January 29, 2010 12:32 PM
To: Murty Maganti
Subject: Re: [mapserver-users] C# query method
Murty,
It's up to the driver how the filter is actually used, but the query
methods should normally use the specified filter setting to limit the
shapes retrieved from the data source.
Best regards,
Tamas
2010/1/29 Murty Maganti <MMaganti at oriongis.com>
Hi
I want to know if a layer's filter (set using layerObj.setFilter method)
is used while executing any of the query methods on a layer like
queryByShape, queryByAttributes, queryByRect etc.
Thanks
Murty
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100129/cacc1d90/attachment.html
