[mapserver-users] UMN + Postsgis, features skipped
Michael Schulz
mschulz at webgis.de
Mon Jul 12 09:31:55 EDT 2010
Hi Andreas,
could you try the map-file with the layer EXTENT removed and see if
that improves the situation? I seem to remember having a similar
problem, with the layer extent parameter, that is generated by the
QGIS mapfile exporter.
Cheers, Michael
2010/7/12 Andreas Neumann <a.neumann at carto.net>:
> Hi all,
> I have troubles with the UMN/Postgis combo. When I just draw the layer
> with a single class, it draws fine, but as soon as I use classification
> with an EXPRESSION (simple string comparison), a lot of features are
> skipped.
> Attached I am sending a mapfile with just one class (buildings from a
> landcover table). Most buildings are skipped, only a few are drawn.
> I have no idea why.
> The same table draws fine without problems in QGIS.
> Any idea why the classification is skipping many features?
> Thanks a lot,
> Andreas
> Andreas Neumann
> http://www.carto.net/neumann/
> http://www.svgopen.org/
> mapserver-users at lists.osgeo.org
Aufwind durch Wissen!
Qualifizierte Open Source Schulungen bei der
http://www.foss-academy.eu/
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
Schwimmbadstraße 2
D-79100 Freiburg i. Br.
Tel: +49 (0)761 705798-102
Tel: +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
