[mapserver-users] Windows 2008; Java; 64 Bit
Tamas Szekeres
szekerest at gmail.com
Wed Jul 14 10:49:44 EDT 2010
Benedikt,
Thank you, I'll look into the solution and apply that, if no one else would
want to take over this.
Best regards,
Tamas
2010/7/14 <umn-ms at hydrotec.de>
> Hi
> I think I have analyzed the problem: Bug in Allocating/freeing char-Arrays:
> *trac.osgeo.org/mapserver/ticket/3491*<http://trac.osgeo.org/mapserver/ticket/3491>
> I'm not quite shure, wether I shall spend time in a workaround or somebody
> can provide a quick solution.
> Bye, Benedikt
> Tamas Szekeres <szekerest at gmail.com> schrieb am 13.07.2010 16:43:53:
> > 13.07.2010 16:52
> > An
> > Kopie
> > mapserver-users at lists.osgeo.org
> > Thema
> > Re: [mapserver-users] Windows 2008; Java; 64 Bit
> > Benedikt,
> > It may be a bug in the mapscript Java bindings, feel free to create a
> ticket
> > for this issue.
> > Best regards,
> > Tamas
> > 2010/7/13 <umn-ms at hydrotec.de>
> > I want to use Mapserver in TomCat6; Windows 2008; 64 Bit; Sun-Java
> 1.6..21
> > Mapserver compiled by Tamas Szekeres: release-1500-x64-gdal-1-7-
> > mapserver-5-6.zip (vbkto.dyndns.org/sdk/Default.aspx )
> > Unfortunately the Java-VM crashes!
> > To reduce the problem I tried example-programs in <UMN>\mapscript
> > \java\examples\
> > - MakePoint runs without error.
> > - QueryByAttribute results in the same crash as the "big-tomcat-
> > environment" does.
> > As far as I can see, the crash occurs every time, when a string-
> > parameter ist provided to the Mapserver API.
> > I think, that the VM-crash occurs, when the function
> > "JNU_GetStringNativeChars(jenv, jarg1)" from mapscript_wrap.c
> > is called.
> > Surprinsingly the error occurs with other release-XXX-packages fromTamas
> too.
> > It even occurs, when I use a 32-Bit-Environment an MS4w on this computer.
> > I attach an hs_err_pid-xxxx.log-File.
> > Does anybody has any advice?
> > Greetings, Benedikt
> > mapserver-users mailing list
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100714/daaef782/attachment.html
