[mapserver-users] Re: multiple map layers with different scales
easyl
thlin.box at gmail.com
Tue Jul 20 09:30:38 EDT 2010
then I tried
mapserv?map=mapfile.map
&layers=ALL
&mode=MAP
&mapxy=12+45
&buffer=30
&mapsize=500+500
&SCALEDENOM=45000
The mapserver just calculated out an extreme large extent and the region
where I am interested in is rendered as small as just one point. (larger
SCALEDENOM -> larger extent)
According to http://mapserver.org/cgi/controls.html the mapsize or imgsize
should only affect the pixel size of output image. The "buffer" should work
with mapxy for limiting map extent. But changing the "buffer" in above
example did not affect the map extent.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/multiple-map-layers-with-different-scales-tp5292120p5316617.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
