[mapserver-users] Java MapScript and Tomcat6 Hanging
Umberto Nicoletti
umberto.nicoletti at gmail.com
Thu Jul 22 10:04:14 EDT 2010
Hi Paul,
please define hang: is it a crash or simply a momentary stall?
In the case it is the latter I see the synchronized keyword in the
definition of the doLogic method and by looking at the code you have
posted it seems superflous, but there might be some other code that
you didn't post that makes it necessary. Anyway I would start looking
there.
HTH,
Umberto
On Wed, Jul 21, 2010 at 4:41 PM, Gilbertson, Paul <paulbe at ceh.ac.uk> wrote:
> Good folks,
> I am somewhat new to MapServer and MapScript, and I'm trying to do a few experiments with Java Mapscript in order to scope out MapServer's feasibility for a large project.
> I've downloaded and installed MS4W 3.0 beta 11, and Netbeans 6.9 with Tomcat 6.0.29 in order to test out Java Mapscript. I created a most basic servlet to serve up simple map tiles, and it works for serial requests. When I try to serve two requests at the same time Tomcat hangs hard.
> My map file and Java classes are below:
> MAP
> IMAGETYPE PNG24
> NAME "nbndemo"
> STATUS ON
> EXTENT -12.5 12.5 700000 1300012.5
> SIZE 800 800
> IMAGECOLOR 226 245 255
> CONFIG "MS_ERRORFILE" "/ms4w/apps/nbndemo/error.txt"
> DEBUG 5
> PROJECTION
> "init=epsg:27700"
> END
> LAYER
> NAME os250k
> STATUS ON
> TILEINDEX "/OSRasterTiles/os_250k/os250k_tindex_srs.shp"
> TILEITEM "Location"
> TYPE RASTER
> OFFSITE 71 74 65
> PROJECTION
> "init=epsg:27700"
> END
> END
> END
> public class SPRewriter {
> public synchronized void doLogic(HttpServletRequest request, HttpServletResponse response) throws Exception
> ServletOutputStream out = response.getOutputStream();
> edu.umn.gis.mapscript.mapObj mo = new mapObj("/ms4w/apps/nbndemo/mapfiles/test.map");
> imageObj image = mo.draw();
> response.setContentType(image.getFormat().getMimetype());
> out.write(image.getBytes());
> image.delete();
> mo.delete();
> protected void processRequest(HttpServletRequest request, HttpServletResponse response) throws ServletException, IOException {
> try {
> SPRewriter spr = new SPRewriter();
> spr.doLogic(request, response);
> } catch (Exception e) {
> e.printStackTrace();
> Any thoughts why this would hang the moment I try to run parallel requests?
> Regards,
> Paul Gilbertson
> This message (and any attachments) is for the recipient only. NERC
> is subject to the Freedom of Information Act 2000 and the contents
> of this email and any reply you make may be disclosed by NERC unless
> it is exempt from release under the Act. Any material supplied to
> NERC may be stored in an electronic records management system.
> mapserver-users at lists.osgeo.org
